LS or GSR tranny
All of those hydro B series parts will interchange in those transmissions like Dax said. I don't know what your engine/car combination is but the GSR trans is good investment over the LS trans IMO
**the LSD is not interchangeable though**
Modified by BROOD at 8:01 AM 8/11/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 »</TD></TR><TR><TD CLASS="quote">I thought an LS LSD was interchangable w/ B16, and a GSR LSD was interchangable w/ type R?</TD></TR></TABLE>
I believe you are right. Ls Lsd cant go in gsr or the other way around
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT »</TD></TR><TR><TD CLASS="quote">Will an LS clutch, flywheel, and LSD fit into a GSR tranny? Im looking at either upgrading to a GSR tranny or just getting a new LS tranny</TD></TR></TABLE>
You cannot put any B-series tranny parts in other B-series tranny's.
LS and B16
GSR and Type R
THAT IS CORRECT!
LS and B16
GSR and Type R
THAT IS CORRECT!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMS MIKE »</TD></TR><TR><TD CLASS="quote">
LS and B16
GSR and Type R
Why? I was under the assumption that the guts were pretty much the same. I know that some B-series transmissions use those two piece bearings [which suck], but you can change those to the one piece bearings.
LS and B16
GSR and Type R
I have an LS trans that needs rebuilt if you want it. also, depending on what you're doing, the LS trans may be better. if you've got serious power, I recommend the LS. I put that in my tegra and it's a really badass gear set on the highway.
Guest
Posts: n/a
Ive got an LS tranny right now, that just needs a 1st to 2nd synchro and it would be fine. THanks for the offer though. Anyone 100% sure about whether or not I can use a LS clutch/flywheel/LSD with a GSR tranny w/o changing anything around?
DJNauTicz
32
Oct 16, 2007 10:03 AM
EH2LS
Jul 21, 2003 12:10 PM
