Camshafts: Skunk2 Stage 1 vs Stock ITR - Dyno results
Here was my ''old'' setup:
98 B18C1
USDM 81.25 ITR pistons
ITR Cat-back/cat
ITR Cams
ITR P73 ECU
ITR Valves springs
Skunks 2 IM
63.5mm TB
DC 4-2-1
Apexi VAFC
AEM 3'' intake
AEM Cam gears
I have made 176.4 whp and 128.9 tq last year.
Added or changed from the old set up is a FPR + Skunk2 retainers + Skunk2 Stage1 cams + my stock P72 ECU with a 9100RPM redline.
Now 182.2 whp and 128.8 tq
Good or no good?
I guess thats good, whats the compression with the USDM ITR OS slugz? I know RainmanEK made close to 200 WHP with skunk2 stage 1s, but he was using JDM ITR OS slugs + mugen headgasket..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiCE On IcE 2 »</TD></TR><TR><TD CLASS="quote">isn't the skunk 2 ITM just a ITR ITM?</TD></TR></TABLE>
same w/ bigger inlet.
that's really low.
i had comptech short ram, dc jdm 4-1, bored throttle body to 69mm with spoon axle back made 182 whp.
that's really low.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">on the same dyno?
overlay the plots and let's see the midrange #'s.....</TD></TR></TABLE>
This is true.
< trapped 100.89mph with "only" 173whp in a stock weight ITR with Skunk stage ones.
This is true.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrasi »</TD></TR><TR><TD CLASS="quote">
that's really low.
i had comptech short ram, dc jdm 4-1, bored throttle body to 69mm with spoon axle back made 182 whp.</TD></TR></TABLE>
Did you ever think to ask what type of dyno? Probably different.
that's really low.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N »</TD></TR><TR><TD CLASS="quote">
Did you ever think to ask what type of dyno? Probably different.</TD></TR></TABLE>
maybe if you just read above u..........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrasi »</TD></TR><TR><TD CLASS="quote">maybe if you just read above u..........</TD></TR></TABLE>
I believe Chris N is asking if YOU dyno'd your car on the same dyno as the OP. If not, comparing your numbers to his is basically pissin' in the wind.
The original poster meant HE used the same dyno for HIS runs.
This is what really annoys me about your posts; the bad English is excusable, but you have <u>nothing to contribute</u> except "i had comptech short ram, dc jdm 4-1, bored throttle body to 69mm with spoon axle back made 182 whp." and "you're not JDM enough."
Before I can find someone with a scanner... here's a few numbers...
ITR Cams @ +4 -2
RPM WHP WTQ A/F
4000 89.3 117.3 13.6
4500 99.6 116.2 14.5
5000 106.3 111.7 13.6
5500 118.6 113.3 13.5
6100 149.7 128.9 13.5
6500 157.2 127 13.2
7000 164.9 123.7 12.9
7500 175 122.5 13
7900 176.4 117.3 13.1
8500 167.2 103.3 12.8
Skunk2 Cams @ +2 -2
RPM WHP WTQ A/F
4000 90.4 118.7 13.6
4500 103.1 120.3 14.1
5000 106.7 112.1 13.5
5500 120.1 114.7 13.9
6100 149.6 128.8 13.5
6500 159.3 128.7 13.9
7000 168.6 126.5 13.6
7500 176.8 123.8 13.6
8000 182.2 119.6 13.8
8500 170.2 105.2 13.7
9000 159.5 93.1 13.5
I have all my dyno in a Excel file... if someone wants it... just ask me...
Modified by Dom_GsR at 11:19 PM 8/10/2004
ITR Cams @ +4 -2
RPM WHP WTQ A/F
6500 157.2 127 13.2
7500 175 122.5 13
Skunk2 Cams @ +2 -2
RPM WHP WTQ A/F
