Headlight Problem! power is getting to the connector, HELP!!
Old Aug 10, 2004 | 05:41 AM
WRTEG's Avatar
Default Headlight Problem! power is getting to the connector, HELP!!
I have a 94 integra and having problems with my drivers side low beam, i have tested the connector itself with a test light and it did light up, bulbs are not blown because i took the working one out of the passenger side and put it in the drivers side but didn't work!
anyone have any ideas what this might be? break in the wire? if so anyone know or have a diagram of how the headlight wires routes itself through the engine bay? or any help at all, this is driving me nuts
Old Aug 10, 2004 | 09:06 AM
hadehatch's Avatar
Default Re: Headlight Problem! power is getting to the connector, HELP!! (94IntegraNL)
check the grounds... Theres this small plastic covered piece that is bolted on to the frame around the headlight area.. That is where all the grounds are grounded to the battery.. Try unbolting it and cleaning that area..
Also check the actual ground wire for that bulb..
Old Aug 10, 2004 | 10:52 AM
WRTEG's Avatar
ok i'll try that out.
Old Aug 11, 2004 | 12:12 AM
PnX-R's Avatar
If you think there's a break in the wire, wiggle or jerk it..
Old Aug 14, 2004 | 07:00 PM
WRTEG's Avatar
grounds seems to be good
Old Aug 25, 2004 | 06:25 AM
WRTEG's Avatar
BUMP!! still can't find the problem.
1 more thing i noticed i can tap the bulb on a piece of metal in the engine bay and the light will flicker, but that's all that will happen, won't turn on other then that.
BrayzieEF9
Jan 14, 2010 10:01 AM
Z.E.R.O.
Apr 7, 2009 06:32 PM
EM2Thrasher
Honda Civic (2001 - 2005)
May 10, 2006 06:29 PM
ebp 99 si
13
Jun 3, 2004 11:20 AM
