Will a faulty combination switch cause the following things?
Old Aug 9, 2004 | 10:46 PM
Slow89HB's Avatar
Default Will a faulty combination switch cause the following things?
1. Turn on left turn signals, all lights flash, inclding gauge lights.
2. With headlights on, left turn signal icon stays lit, left turn signal dosnt work
3. With headlights on, all left turn signal lights stay on.
Could this be a bad ground?
What grounds should I check?
Is it the combination swtich?
How much does a combination switch usually cost from a junkyard?
Is it possible theres a short?
Ask me any questions about whats its doing, and maybe I can answer them.
Old Aug 10, 2004 | 07:14 AM
Synth124's Avatar
Default Re: Will a faulty combination switch cause the following things? (Slow89HB)
What you need to do is tell us what this cambination switch is hooked up to. What functions does it carry out?
Old Aug 10, 2004 | 08:06 AM
T-Mo's Avatar
That is a normal problem with combination switches. What year is your car??
*edit never mind, I assume its a '89 from your name**
The price from Honda new is $148. I just changed out my friends switch which was doing similar things in which you described. It is very easy to do. I pulled a couple of sets from the junkyard @ $30 each.
What you need mainly in this pic is #11, which is $105 from honda, but it is best to buy the whole assembly for $150 or hit the junkyards.
http://www.slhondaparts.com/im...1.jpg
The extra one that I have is a '91 combo. switch. This may not work in 88-89's though. Thats why I pulled two. The job itself is VERY easy. You take the steering wheel off, unscrew 4 little screws holding it on, and pull it out.
My97CX
Mar 8, 2013 04:55 PM
31flavorscivic
Dec 17, 2008 11:01 AM
jArceo
Feb 14, 2006 11:25 AM
itsallmotor
Mar 19, 2003 06:33 AM
Zubz
Oct 12, 2002 07:51 AM
