Compustar 2WSS-AS alarm, anyone have it?
I got the Compustar 2WSS-AS alarm system w/ remote start about a month ago. Just curious if anyone has any experience with this alarm and if it is a decent system, etc. Also, I am installing the remote start on my 1994 Integra (stick shift), so I know I have to bypass the clutch. Any recommendations on doing this as far as what parts of the relay need to be connected to what wires. Also, what are the affects of having a remote start on a stick shift. I already have to have the car in neutral when I park because of my turbo timer, so that's not a problem. Any adverse affects?
Thanks
Thanks
also, how easy is it to add on features and accessories? for instance, i got the dei modules for automatic window roll-up and sunroof closing when i arm the system, but in the future i may want to integrate my neon lighting and/or strobes into the system, and eventually possibly autoloc door poppers, etc. thanks again
PS - should i hook up the alarm to my primary or secondary battery (which is in the spare tire well)?
You shouldn't have to "bypass" the clutch. The compustars are designed to work with a manual transmission. In order for the unit to work on a manual you have to put the car into whats called "reservation" mode when you turn it off. To do that you take the car out of gear and apply the e-brake without touching the brake pedal. You touch the brake pedal at all and the car will not start cause it makes the module "think" that the car might still be in gear.
I still think the clutch should be bypassed. There is nothing on that alarm that will make it somehow bypass it...at least I didn't find it.
EMILYKHAMPOU
Audio / Security / Video
17
Dec 21, 2014 09:15 AM
cccya
29
Jun 27, 2003 10:48 PM
