weird buzzing sound at startup
Old Aug 9, 2004 | 10:31 PM
l4 soldier's Avatar
Default weird buzzing sound at startup
everytime i start up my car there is a weird buzzing noise. then after a couple secs of buzzing its gone. my friend says it could be normal and it may be the ecu?? any ideas?
Old Aug 9, 2004 | 10:33 PM
The-LS's Avatar
Default Re: weird buzzing sound at startup (l4 soldier)
possibly the fuel pump priming up.
Old Aug 9, 2004 | 10:52 PM
l4 soldier's Avatar
Default Re: weird buzzing sound at startup (Black-LS)
umm alrite thanks since im a complete n00b i need to look into wat a fuel pump is...
Old Aug 9, 2004 | 11:02 PM
Sack Master's Avatar
Don't know what a fuel pump is? Hint - IT PUMPS THE FUEL . Just playin buckaroo. It's probably your ABS which will do that all the time. Under the assumption you don't know what ABS is it means ANTI LOCK BRAKE SYSTEM. If your car has that then I can almost guarantee to you that is what you hear. If you car has that and the sound is coming from the engine compartment(Thats the compartment your engine is in). Then it's nothing to worry about.
Old Aug 10, 2004 | 12:44 AM
Cliffjumper2's Avatar
Default Re: weird buzzing sound at startup (Sack Master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">Don't know what a fuel pump is? Hint - IT PUMPS THE FUEL . Just playin buckaroo. It's probably your ABS which will do that all the time. Under the assumption you don't know what ABS is it means ANTI LOCK BRAKE SYSTEM. If your car has that then I can almost guarantee to you that is what you hear. If you car has that and the sound is coming from the engine compartment(Thats the compartment your engine is in). Then it's nothing to worry about.</TD></TR></TABLE>
second that; it's your ABS system. Completely normal for an integra with abs. Have someone else start your car while you stand by your passenger side fender, by your engine, and you'll hear it clearly.
Old Aug 10, 2004 | 09:50 AM
l4 soldier's Avatar
Default Re: weird buzzing sound at startup (DCcliffjumper2)
thanks alot guys
Old Aug 10, 2004 | 09:52 AM
grlstockb18c1's Avatar
Could be ABS...does ur ABS light come on?? I just took out the fuse
Old Aug 10, 2004 | 09:54 AM
..::91TEG-G2::..'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCcliffjumper2 &raquo;</TD></TR><TR><TD CLASS="quote">
second that; it's your ABS system. Completely normal for an integra with abs. Have someone else start your car while you stand by your passenger side fender, by your engine, and you'll hear it clearly.</TD></TR></TABLE>
and i third that.. ABS system, bugs the **** out of people.. but oh well
Old Aug 10, 2004 | 10:02 AM
l4 soldier's Avatar
Default Re: weird buzzing sound at startup (..::91TEG-G2::..)
nope the ABS light doesnt come on. just the sound then its fine
Exeed
Jan 26, 2007 07:25 PM
bayne
Sep 20, 2006 10:01 AM
Fat Chick Magnet
Aug 29, 2006 05:55 AM
Eluzion
Apr 11, 2004 09:51 PM
integra7
May 23, 2002 09:39 PM
