Running to lean?
Old Nov 29, 2001 | 09:39 PM
RedRacerCivic's Avatar
Default Running to lean?
How can you tell if your car is not getting enough fuel, I recently bought a B&M FPR and i tuned it without a gauge, Today,For the first time ever, my check engine light came on when i was driving on the freeway, checked ECU:code 1(oxygen content) Is it bad to drive around like this? My car used to run rich, but the way how my FPR is adjusted, im getting very good gas milage. Should i adjust the pressure higher? Or is it good how it is now?
Old Nov 29, 2001 | 11:31 PM
Turbohatch's Avatar
New User
Default Re: Running to lean? (RedRacerCivic)
check the spark plugs:
a white tip of the spark plug = lean
a light brown tip of the spark plug= perfect air to fuel mixture
a black tip of the spark plug= rich
get a air to fuel gauge or a egt to tell then tune to what is best for you car!!!!!
Old Dec 5, 2001 | 10:36 PM
zerospooon's Avatar
just buy some cheap gas that like 50% water at am/pm - so it will balances out to a perfect miture - a double whamy (solves problem/save money)
Old Dec 6, 2001 | 12:46 PM
One8Hatch's Avatar
New User
Default Re: Running to lean? (zerospooon)
are you sure am/pm gas has 50% water? cus if you put water in the cyl. it will tear sheit apart right?
PoorManR_CRX
Jan 21, 2014 09:27 AM
nd94cx
Sep 21, 2004 07:29 PM
respectblades
Jan 19, 2003 02:40 PM
widecoupe
Dec 7, 2001 01:45 PM
RaVAGE00
Sep 26, 2001 11:42 AM
