How to tell if your o2 sensor is broken
hi, just wondering how would you tell if your o2 sensor on a OBD-1 car is not working? Im pertty sure it wont throw any codes but can what are some ways to tell/test it to see if its working.
Cheers
Cheers
I believe one logical symptom would be that it runs rich or lean for a really long time.. Because the Block Learn/Fuel Trim numbers change according to the O2S. And if the O2S is slow to respond or doesn't respond, the Fuel Trim numbers won't change..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tianporn »</TD></TR><TR><TD CLASS="quote">... o2 sensor on a OBD-1 car is not working?</TD></TR></TABLE>That's code #1. But I think it has to be real bad, not marginal.
Voltmeter while it's plugged in & running... It should oscillate quickly around 0.5volts. An oscilloscope would be good, but some voltmeters are fast enough to see the fluctuations.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vmm »</TD></TR><TR><TD CLASS="quote">ya i can smell gas from inside the car..could it be o2 sensor issues?</TD></TR></TABLE>That can be 50 different things, but O2 sensor isn't the first thing to my mind...
Say if I unplugged the o2 sensor and drove the car around the the car runs absolutely **** then would that mean my o2 sensor is fine. But if it runs the same can I conclude the o2 sensor is broken?
4tika4
Jul 25, 2009 05:23 AM
