Tranny problem, throw-out bearing.
Old Aug 9, 2004 | 02:07 PM
Takumi Fujiwara's Avatar
Default Tranny problem, throw-out bearing.
I pressed the clutch in at about 6500RPM on my B18b and my car stopped going into any gears. When I finally did grind it into a gear, even with the clutch pedal to the floor, the car would accelerate. Knowing there was a serious problem, I had it towed to a local shop and had the clutch replaced, by their recommendations. (The throwout bearing looked a bit damaged).
Afterwards, when I was driving home, it would go into all the gears, but every gear felt like neutral. The RPMs would climb, but I wasn't going anywhere. Again, I had it towed to the shop.
What would cause something like this? I would rather not buy a new tranny and pay labor all over again.
Thank You.
Old Aug 10, 2004 | 04:58 AM
BudMan's Avatar
Default Re: Tranny problem, throw-out bearing. (Takumi Fujiwara)
sounds like they did a crappy job on the clutch install. "Warranty" time. The bearing wouldn't stop the car from engaging.
Old Aug 10, 2004 | 06:52 AM
TrueUntilDeath.com's Avatar
Default Re: Tranny problem, throw-out bearing. (BudMan)
clutch slipp
Old Aug 10, 2004 | 07:09 AM
IN VTEC's Avatar
Possibly popped out an axle?
Old Aug 10, 2004 | 01:24 PM
Default Re: Tranny problem, throw-out bearing. (IN VTEC)
From what I have heard from a couple members, it seems maybe the spring on the release fork got knocked loose while the casing was put on... either that or the release bearing popped off the fork, or the spring under the fork got knocked off...
I'll keep you posted, my car is still at the shop.
Modified by Takumi Fujiwara at 8:34 PM 8/10/2004
SlimNubster
Honda Civic (2001 - 2005)
Jul 14, 2010 08:10 AM
JDM3STAGEVTEC
Dec 19, 2008 07:43 PM
ACottrell
Apr 20, 2005 05:01 PM
doublejz
Mar 9, 2004 01:19 PM
AzntaggeR
Feb 18, 2003 06:01 PM
