What kind of cams do I have? B18B1
Old Aug 9, 2004 | 12:39 PM
WiLLMaTiX's Avatar
Default What kind of cams do I have? B18B1
Does a B18B1 have roller cams or flat flap(i think thats what their called)???
Old Aug 9, 2004 | 01:03 PM
WiLLMaTiX's Avatar
Default Re: What kind of cams do I have? B18B1 (WiLLMaTiX)
Anyone who has opened their head please tell me if your rocker arms have little rollers on the end or if they are just metal tab things, thanks - will
Old Aug 9, 2004 | 01:04 PM
shamoo's Avatar
Will you make something up for me please?
"Metal tab things"
Old Aug 9, 2004 | 01:14 PM
WiLLMaTiX's Avatar
Default Re: What kind of cams do I have? B18B1 (shamoo)
alrighty thank you, do you know if theres any kits or any way to make mine roller cams? I know on crazy high reving and high power motors they use rollers because they can have a steeper angle on the lobes to allow the valves to open more and stay open longer, any ideas?
Old Aug 9, 2004 | 01:32 PM
shamoo's Avatar
I'm not sure there's anything out there for this type of conversion.
But what are you looking to do? I'm sure there is some combination of valve spring/retainer head package that will achieve your goal. There are so many choices out there.
Plus, you can always go LS/Vtec. Once you go there, even more options are open to you.
Old Aug 9, 2004 | 01:47 PM
non-VTEC's Avatar
there is no roller valve train setup for the non-vtec head.
crane cams make a full roller valve train and camshaft setup for the VTEC head. it's very expensive though which is why hardly anyone uses it.
Old Aug 9, 2004 | 08:17 PM
WiLLMaTiX's Avatar
Default Re: What kind of cams do I have? B18B1 (non-VTEC)
ohh ok thanks I was just wondering, my goal honestly is to stroke my motor to 1.98 liters with a b16 head. Get everything balanced really well, so theres almost no limit to the RPM's before power cuts out and just keep it all motor. But thats not for a long *** time, most likely just an LS-T for now. And if I can afford it perhaps LS/Vtec instead... Not too sure, im weighing my options now. I was thinking alot about gettin I/H/E(2.75 inch, just headers a cat, and a 24 inch resonator with no muffler and a true peice of straight tubing) Intake Manifold, Throttle body, crower cams (Street/Track) Apex'i SAFC controller, new clutch, and cam gears. So I dont know, im so lost on what to do. Like whats best for the price.
Muckman
Apr 7, 2012 06:56 AM
EFjoe91
54
Mar 10, 2011 08:17 AM
JDM_EK4_Coupe
May 15, 2007 06:21 PM
Ryan15
Sep 13, 2006 06:45 AM
rough_draft
May 16, 2005 12:49 AM
