Maintenance schedule
Can anyone tell me how often I should change/replace the following? I have a 1990 Civic SI with 258000+ kms and my car is stock.
Transmission fluid
Brake fluid
Coolant
Spark plugs
Air filter
Fuel filter
Anything else I'm missing?
Transmission fluid
Brake fluid
Coolant
Spark plugs
Air filter
Fuel filter
Water pump, oil pump, Timing belt, ac belt, power steering belt, alternator belt, dizzy cap and rotor, brakes, rotors, CV axel boots if cracked/torn, basically there's an endless list of things which 'Could' need replacing. But if your like the other 98% of us who wait till its broken to fix it, just go with the fluids, T belt, filters, dizzy/rotor, plugs/wires, flush radiator and get a compression check. - Darrell
yeah, I have a similar situation... 1991 CRX Si in a great shape but with 220K on it ... The water pump was first to go ... Then some electrical problems ... I installed CAI and new exhaust system. Now I basically take care of my rex in every way, but what else to expect/change?
Also, my question is how many more K can I get before a major engine/tranny problem? I am planning a ZC swap but not until then.
Any guesses?
Any guesses?
attest53
Mar 5, 2006 08:56 AM
