HELP, EXPERTS!!! I've taken apart my bellhousing and can't get it closed!
Old Aug 9, 2004 | 10:16 AM
Slimm-rw-'s Avatar
I'm a Jackass
Default HELP, EXPERTS!!! I've taken apart my bellhousing and can't get it closed!
I'm changing my clutch and no whave the tranny off of the engine, but before I got it off, I accidentally took apart the bellhousing, mistaking its bolts for those that held the tranny to the engine. so now there's about 1/2"-1" of space and I can see all the gears and stuff, but I can't get it back together, nor can I take it all the way apart. My haynes manual doesn't cover transmissions in detail, and nobody in my area sells helms manuals. Is there a tutorial somewhere on the web about how to actually take a tranny apart? I've searched and all anyone says is "get a helms...."
Old Aug 9, 2004 | 11:50 AM
nortrop's Avatar
Default Re: HELP, EXPERTS!!! I've taken apart my bellhousing and can't get it closed! (Slimm-rw-)
I would take a look at this post: https://honda-tech.com/zerothread?id=795700. Basically there are 3 or 4 different internal parts which need to line up to close the case. In addition you need to line up an internal snap ring just right.
Take a look at that post and you will see what I mean. Finish removing the transmission and reassemble the housing with it off the car. It's near impossible to do it while it's still connected to the engine block.
prelude1897
Mar 31, 2005 12:20 PM
Slimm-rw-
Aug 9, 2004 01:29 PM
jerbear!
Jun 27, 2004 02:40 PM
Furry
Jan 5, 2003 07:45 AM
