What are symptoms of a bad 02 sensor?
Old Aug 9, 2004 | 10:09 AM
ashleeb's Avatar
Default What are symptoms of a bad 02 sensor?
What are symtoms of a bad 02 sensor? Can they only cause problems after the car is warmed up because when they are cold they are in open loop mode?
Old Aug 9, 2004 | 10:25 AM
Filthy Focker!'s Avatar
Default Re: What are symptoms of a bad 02 sensor? (ashleeb)
Yup... O2 sensors need to be heated up to about 600 degrees in order to kick in... Got problems?
fs
Old Aug 9, 2004 | 11:00 AM
philadd's Avatar
a couple that come to mind: the gas mileage will almost always drop some, stumbling and hesitation are usual symptoms, but not necessarily always present.
what problems are you having?
Old Aug 9, 2004 | 11:02 AM
ashleeb's Avatar
Default Re: What are symptoms of a bad 02 sensor? (filthy_shovel)
The car stubles and almost dies when you take off after the car has been sitting and cold. It gets better as the car warms up but is terrible at first.
Old Aug 9, 2004 | 11:05 AM
philadd's Avatar
Just found your other post, but yes, a bad or "slow" o2 sensor will cause these problems
Old Aug 9, 2004 | 07:38 PM
tjohnson329's Avatar
get a voltmeter and back prob the o2 sensor and check the voltage
Mohsin
22
Sep 18, 2018 04:31 PM
4tika4
Jul 25, 2009 05:23 AM
ruffrhyder
Engine Management and Tuning
Sep 25, 2008 07:56 PM
Civicman86
Apr 30, 2006 02:20 PM
Slow Egg
Oct 6, 2002 10:57 AM
