SAFC II Problems on D16a6 with PM6
Old Aug 9, 2004 | 07:37 AM
Todd00's Avatar
I said I don't want a title!
Default SAFC II Problems on D16a6 with PM6
Anyone ever installed an SAFC II on this combination (D16a6 + PM6 ECU)? Cr ais a 91 Si.
I tried, but I'm having some issues. I will triple check my wiring, but when I start the car up it idles very, very poor. And every time I give it gas, it seems to reset the SAFC II (goes back to the title screen when the throttle is pushed).
Other than my wiring, anything else to look out for? Did I perhaps not follow the pinout directions correctly (I did what was listed in the Apexi manual) and I left the pink and blue wire not hooked up.
Thanks.
Old Aug 9, 2004 | 07:50 AM
13sechatch's Avatar
my thoughts are double triple and check check check the wiring something is def off on that if ts resetin the afc. other than that make sure you set it up right(car type & throttle selection)
Old Aug 9, 2004 | 08:05 AM
Todd00's Avatar
Default Re: (13sechatch)
Settings I did:
4 cylinder
pressure
06, 06
arrow to the 2 o'clock position
I was doing the two stars for the throttle and the settings wouldn't even save.
All of ths sound correct?
Old Aug 9, 2004 | 10:57 AM
13sechatch's Avatar
the 06, 06 arent they need to be 01,01
Old Aug 9, 2004 | 11:11 AM
Todd00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 13sechatch &raquo;</TD></TR><TR><TD CLASS="quote">the 06, 06 arent they need to be 01,01</TD></TR></TABLE>
Manual shows it as a PR-6. How do you determine it is a 01, 01? Pr = pressure and 6 = 06...or so I thought.
Are the other settings correct, though?
Old Aug 9, 2004 | 11:42 AM
13sechatch's Avatar
i have the safc2 in my ef with a b16 the book says most applications use 01,01 i tried to use others and it ran like hell just try it and see if it works mine did. i know the vafc1 says 06,06
Old Aug 9, 2004 | 03:47 PM
Todd00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 13sechatch &raquo;</TD></TR><TR><TD CLASS="quote">i have the safc2 in my ef with a b16 the book says most applications use 01,01 i tried to use others and it ran like hell just try it and see if it works mine did. i know the vafc1 says 06,06</TD></TR></TABLE>
I tried the 01, 01 setting and the Safc won't save that setting. The only setting it seems to want to save is 06, 06.
Since I don't know the default behavior of this device, I'm not sure what's going on.
Old Aug 10, 2004 | 04:15 AM
13sechatch's Avatar
what are you doing to make it save the setting all you have to do is change it then turn the key off and it should save it. hope your not hitting the initialize all that resets the afc.
Old Aug 10, 2004 | 06:45 AM
Todd00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 13sechatch &raquo;</TD></TR><TR><TD CLASS="quote">what are you doing to make it save the setting all you have to do is change it then turn the key off and it should save it. hope your not hitting the initialize all that resets the afc.</TD></TR></TABLE>
Nope. Just making the changes then turing the ignition key off. The device only wants to save certain settings it seems. It just won't accept 01, 01.
Old Aug 10, 2004 | 06:57 AM
AychTwenee2's Avatar
Are you sure your wiring is correct? There are only like 4 or 5 wires you need to hook up, because you are not turbo or anything. Just make sure you read the plugs right on the harness. It's easy as hell to hook up.
Old Aug 10, 2004 | 06:59 AM
Since they do not have a diagram for the pm6, you need to find out where the same wires are at on your ecu that they call for in the booklet that has all the different ecu's. TPS, O2, etc......
Old Aug 10, 2004 | 07:03 AM
Todd00's Avatar
Default Re: (VeeTekCrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VeeTekCrx &raquo;</TD></TR><TR><TD CLASS="quote">Since they do not have a diagram for the pm6, you need to find out where the same wires are at on your ecu that they call for in the booklet that has all the different ecu's. TPS, O2, etc......</TD></TR></TABLE>
Would it be the same as a 86-89 Integra or something like that? I used the wiring for an EF8 (88-91 Civic with B16a). Perhaps this is where my problem is...
Old Aug 10, 2004 | 07:16 AM
13sechatch's Avatar
just use the wiring for the car it should be like H-1 or something but thats the right diagram you sure you looked at the conectors at the right view. just go back over it again. something has to be wrong in the wiring
Old Aug 10, 2004 | 07:17 AM
get the diagram for a pm6 and match wires. The b16 is not the same. That will probably fix your problem.
Old Aug 10, 2004 | 07:21 AM
13sechatch's Avatar
the ecu is not the same but unless you changed wiring in the car thats all you go by is the car wiring diagram. doesnt matter what ecu it is the same diagram is used for my 89 si with b16 as it is on my 92 vx with b18b and was the same on my 90 teg with b16a and i used the same one on my buddies crx with stock motor the ecu makes no difference as long as you use the diagram for your car it should work if you keep having probs then un hook it completely and see how it runs
Combustion Contraption
Dec 14, 2005 08:55 PM
lilredhatch
Sep 25, 2004 04:49 PM
lilredhatch
Sep 24, 2004 05:30 PM
TurboEG6
Sep 23, 2003 08:19 AM
SOFLSOL
Sep 3, 2003 06:53 PM
