How to identify a bad bearing ?
Old Aug 9, 2004 | 02:25 AM
petrv's Avatar
Default How to identify a bad bearing ?
What should I check to identify if a bearing in a transmission is bad or not? Should the bearing have some play, drag etc?
Old Aug 9, 2004 | 03:40 AM
uNF$@#!'s Avatar
Default Re: How to identify a bad bearing ? (petrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petrv &raquo;</TD></TR><TR><TD CLASS="quote">What should I check to identify if a bearing in a transmission is bad or not? Should the bearing have some play, drag etc?</TD></TR></TABLE>
take the bearing in hand, and spin it round and round. you hear noise? you feel friction? yeah...thats a bad bearing.
Old Aug 9, 2004 | 04:00 AM
SlapSmak's Avatar
Has it been brought home late at night by the police? Do it's friends parents call you and tell you they dont want your bearing talking to their bearing anymore because it is a bad influence? Sure signs of a bad bearing...
Old Aug 9, 2004 | 05:44 AM
petrv's Avatar
Default Re: How to identify a bad bearing ? (w@@t w@@t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by w@@t w@@t &raquo;</TD></TR><TR><TD CLASS="quote">
take the bearing in hand, and spin it round and round. you hear noise? you feel friction? yeah...thats a bad bearing.</TD></TR></TABLE>
Should the bearing have any play? Or there must be NO play?
Old Aug 9, 2004 | 06:20 AM
DutchITR1689's Avatar
No play
Old Aug 9, 2004 | 06:42 AM
petrv's Avatar
Default Re: How to identify a bad bearing ? (DutchITR1689)
Should the bearing be oiled when checking for noises, play etc? For example should I put into a can with oil, pull uop and then rotate? Or should it be dry?
Old Aug 9, 2004 | 08:20 AM
Dan GSR's Avatar
some of the bearings are tighter than others
for example the large bearing on the mainshaft, brand new from the dealer, has lots of play
the inner and outer races can deflect a considerable amount
which bearing are you talking about in particular?
Old Aug 9, 2004 | 08:23 AM
RTW DC2R's Avatar
tranny discussions are useless to me without pictures lol
Old Aug 9, 2004 | 08:36 AM
Dan GSR's Avatar
Default Re: (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">tranny discussions are useless to me without pictures lol</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=795700
Old Aug 9, 2004 | 08:44 AM
RTW DC2R's Avatar
Default Re: (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">
wow bookmarked and saved to notepad
Ryan, who will be disassembling his trans in the coming months and is not looking forward to it lol
Old Aug 9, 2004 | 10:10 AM
AssPenny's Avatar
Ryan, who will be disassembling his trans in the coming months and is not looking forward to it lol</TD></TR></TABLE>
Wow, thats alot of pictures
Ryan, it's not really that hard. I've had my tranny apart a good 5 to 6 times and I'm getting ready to replace all the bearing in it shortly. Manual trannies are pretty straight foward, just make sure you put everything back on in the order you took them off. Watch out for thouse friction rings as putting one on upside down will cause some headaches.
Old Aug 9, 2004 | 11:02 AM
petrv's Avatar
So, here are my pictures and questions:
1) All the upper bearings look like having some play:
2) The lower bearings - one looks tight (no play), but clicks a bit and sometimes, when I rotate it, it slows down and then stops immediatelly - like there is some friction.
3) My clutch bearing (don't know how you call it) has about 1mm play and is very noisy.
4) To summarize my problems: Noise when driving (just cruising) from the trany area. When I'm stopped and tranny in neutral, the noise is present at any RPM (most noticable at 3000). When I push the clutch pedal, the noise stops in about 1-2secs. When I release the clutch pedal, the noise is immediatelly there.
Old Aug 9, 2004 | 11:42 AM
esponet's Avatar
imo, if you already have it out, and apart. just replace it with a new one. even if its still good. don't want to take it apart later just because that one bearing went bad, because you did not replace it before.
Old Aug 9, 2004 | 12:15 PM
AssPenny's Avatar
Default Re: (esponet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet &raquo;</TD></TR><TR><TD CLASS="quote">imo, if you already have it out, and apart. just replace it with a new one. even if its still good. don't want to take it apart later just because that one bearing went bad, because you did not replace it before.</TD></TR></TABLE>
Yep, replace all 5. Call up Len and he'll get you cookin'
Old Aug 9, 2004 | 12:19 PM
Willard's Avatar
here are some pictures of a tranny that I did some work on.
https://honda-tech.com/zerothread?id=640474
Old Aug 9, 2004 | 12:27 PM
Yep, I would replace all of them. Are you the one with the transmission oil that looks like water?
I replaced my tranny oil after 86.000 km. It's just a little bit smoother now, not much. I guess the old oil was still good.
Honda MTF II gets
Old Aug 9, 2004 | 12:39 PM
Dan GSR's Avatar
Default Re: (AssPenny)
#4 is the one that always goes bad, def have to replace that
#1 , brand new, has lots of play up and down
#3 , brand new has lots of play up and down, the outer race is separate from the rest of the bearing
#2 should be be tight, ive seen this one go bad as well, I like to change this one
and lastly, none of the bearings should be making noise
hope that helps
Old Aug 9, 2004 | 12:42 PM
Dan GSR's Avatar
replace all if you can
if $$ is tight replace 1,2,4 and put a brand new nut on the countershaft
also, replace the throwout bearing ( the clutch bearing, as you called it)
Old Aug 9, 2004 | 01:05 PM
db8sirg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">
Yep, replace all 5. Call up Len and he'll get you cookin'</TD></TR></TABLE>
iam doing a lsd, final drive right now. all the bearings seem fine but should i repalce them anyways? tranny has 41k on it.
Old Aug 9, 2004 | 01:15 PM
Dan GSR's Avatar
Default Re: (db8sirg)
at minimum, i'd do #4, it takes a lof of abuse
Old Aug 9, 2004 | 01:35 PM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">at minimum, i'd do #4, it takes a lof of abuse</TD></TR></TABLE>
Old Aug 9, 2004 | 06:35 PM
db8sirg's Avatar
thanks.
Old Aug 9, 2004 | 08:08 PM
uNF$@#!'s Avatar
Default Re: How to identify a bad bearing ? (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">some of the bearings are tighter than others
which bearing are you talking about in particular?</TD></TR></TABLE>
yes...i noticed the large bearing on the maint shaft is very play friendly
I think i have #2 and #4 sitting on my office desk as paper weights.
Old Aug 9, 2004 | 08:51 PM
ultimatehonda's Avatar
That tranny looks really dirty....why does it get like that?? Mine was somewhat dirty too when I cracked it open.
Old Aug 9, 2004 | 09:20 PM
petrv's Avatar
Default Re: (ultimatehonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ultimatehonda &raquo;</TD></TR><TR><TD CLASS="quote">That tranny looks really dirty....why does it get like that?? Mine was somewhat dirty too when I cracked it open.</TD></TR></TABLE>
My friend cleaned the housing with a pressure benzine, now it looks like new . The previous user used 5w50 oil for the tranny
