Honda S2000 Honda S2000
DC Sports Header Gains, DC Header Vs. More Expensive Headers
Old Aug 8, 2004 | 07:26 PM
Heath's Avatar
Default DC Sports Header Gains, DC Header Vs. More Expensive Headers
As the title states, what sort of difference can be seen between the DC header and any of the more expensive headers? Your more expensive headers and double and even triple what one would expect to spend on the DC, but are the gains and construction double or triple to quality of the DC? I remember seeing some numbers in an older "power pages" and it didn't seem bad at all. What do you guys think?
Decent bang for my buck or cheap ricer product?
Old Aug 8, 2004 | 10:17 PM
Mr. Bagel's Avatar
Default Re: DC Sports Header Gains, DC Header Vs. More Expensive Headers (95civicturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civicturbo &raquo;</TD></TR><TR><TD CLASS="quote">As the title states, what sort of difference can be seen between the DC header and any of the more expensive headers?</TD></TR></TABLE>
DC headers weigh in at just under 10 lbs. the stocker. Stock = 22lbs. DC Sports 12lbs. No gains. Zero gains. Nothing, zilch, nada. Others: Spoon, Toda, Mugen are built for a particular purpose and range. If you do not need that range for a particular purpose, then don't bother. Otherwise, it will be just the JDM-Bling-mod.
Old Aug 8, 2004 | 10:27 PM
Heath's Avatar
Default Re: DC Sports Header Gains, DC Header Vs. More Expensive Headers (Mr. Bagel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Bagel &raquo;</TD></TR><TR><TD CLASS="quote">
DC headers weigh in at just under 10 lbs. the stocker. Stock = 22lbs. DC Sports 12lbs. No gains. Zero gains. Nothing, zilch, nada. Others: Spoon, Toda, Mugen are built for a particular purpose and range. If you do not need that range for a particular purpose, then don't bother. Otherwise, it will be just the JDM-Bling-mod.</TD></TR></TABLE>
So what you're saying is that I'll save weight no matter how I look at it, but the more expensive will give me range specific gains only? How did they get the few horse they did from the DC unit in Power Pages?
Old Aug 9, 2004 | 03:50 AM
aklucsarits's Avatar
New User
Most dynos you'll see of the DC Sports S2000 header show it actually losing a few HP over most of the RPM band.
Andrew
Old Aug 9, 2004 | 06:41 AM
Heath's Avatar
Default Re: DC Sports Header Gains, DC Header Vs. More Expensive Headers (aklucsarits)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aklucsarits &raquo;</TD></TR><TR><TD CLASS="quote">Most dynos you'll see of the DC Sports S2000 header show it actually losing a few HP over most of the RPM band.
Andrew</TD></TR></TABLE>
Really? So you guys think I should stick with my stock header?
Old Aug 9, 2004 | 06:46 AM
neo1z's Avatar
Well if it doesnt gain any power...what's the purpose?
If you're gonna do a header - do a header. Toda...or something of the like. Otherwise the stocker does it great.
Old Aug 9, 2004 | 10:44 AM
80's Boy's Avatar
Default Re: DC Sports Header Gains, DC Header Vs. More Expensive Headers (neo1z)
The DC header looks nice and it does save some weight, but no way would oyu find me bolting one on my car. The performance improvements just aren't there with the header.
Old Aug 9, 2004 | 02:31 PM
bluesaint's Avatar
Default Re: DC Sports Header Gains, DC Header Vs. More Expensive Headers (80's Boy)
only header that makes most power and weight saving is "Amuse"
Mugen, Spoon gain's 6-10whp in the midrange, toda, fujitsubo gain's 5-7whp in highrange.
Amuse gain's power overall.
DC Sport=looses power across the board.
Old Aug 10, 2004 | 12:13 AM
evil vapor's Avatar
which dyno's would that be?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluesaint &raquo;</TD></TR><TR><TD CLASS="quote">only header that makes most power and weight saving is "Amuse"
DC Sport=looses power across the board.</TD></TR></TABLE>
I'm sorry to inform you that the statements you're presenting are incorrect. There are so many variables involved in how much power this header makes or that header. If you put all those headers on a s2000 with a stock ecu, you'll likely see the same results with some losing power. I have not seen a dyno of an amuse header with a programable standalone ecu, so I cannot comment on it. I will saw the mugen makes power in the midrange, not lacking any power top end. The toda has a higher output than the mugen across the board. The spoon is lacking. Haven't seen a fujitsubo yet.
Basically, there is power to be gained in each header, and that is determined by the tuner and setup. In order to get every hp, you need to make sure the whole setup is tuned, not just slapping on a header and expecting gains. And don't say the amuse makes the most power because it's the prettiest and most expensive.
Old Aug 10, 2004 | 09:18 AM
bluesaint's Avatar
Default Re: DC Sports Header Gains, DC Header Vs. More Expensive Headers (vapor)
Vapor, you can see the Amuse header dyno in the 2nd edition of Hyper Rev.
Also i personally had the fujitsubo and spoon headers on my S before i switched to Amuse. I think i'm the only one who can attest to how they make power.
Cheers.
Old Aug 10, 2004 | 01:13 PM
Project SSAP1's Avatar
Default Re: DC Sports Header Gains, DC Header Vs. More Expensive Headers (bluesaint)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluesaint &raquo;</TD></TR><TR><TD CLASS="quote">Vapor, you can see the Amuse header dyno in the 2nd edition of Hyper Rev.
Cheers.</TD></TR></TABLE>
got any pics...also do u a have the amuse exhaust to match...i would luv to see any dyno results if u tuned it with an aem ems...I know no setup is alike....im just curious to see what u got
Old Aug 10, 2004 | 02:03 PM
dut's Avatar
dut
Default Re: DC Sports Header Gains, DC Header Vs. More Expensive Headers (Project SSAP1)
- I have a DC header and didn't feel any difference...
- the only reason I got the DC header was because it came with my wideband (dc header had a bung already welded for the o2).. oh, and its a little lighter.. WOW!
Old Aug 10, 2004 | 03:27 PM
Voodoo_s2k's Avatar
Wassup. As you might remember, I was there for the dyno day at Dynolabs with my S that you organized. I had just put on the DC Sport header on my car and I wanted to see for myself if anything was to be gained or lost. The only reason I even bought the header was at only $200 new, it wasn't much money to be lost to try. The results are not truly comparable because the dynos were done on different days, but my car did gain hp and tq in the mid rpm range. I don't remember off the top of my head what the exact numbers are, but max gain was about 5-6hp around 7000 rpm. I didn't gain any peak hp, just some mid range. This was done on a S with stock ecu. Other relevant mods at the time was a CAI. Just my .02.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 80’s Boy &raquo;</TD></TR><TR><TD CLASS="quote">The DC header looks nice and it does save some weight, but no way would oyu find me bolting one on my car. The performance improvements just aren't there with the header.</TD></TR></TABLE>
Old Aug 15, 2004 | 03:43 PM
J'sRacing's Avatar
Toda, Mugen, Amuse
Acc0rdR4c1ng
Jun 21, 2006 08:54 AM
vtec420kingH22
Aug 4, 2005 11:21 PM
jbell
31
Dec 14, 2004 08:34 AM
sleepin91teg
Dec 31, 2003 02:42 PM
jetpilot
Aug 20, 2003 11:37 AM
