Honda S2000 Honda S2000
Lowering Spring or Coilover
Old Aug 9, 2004 | 08:11 AM
ExtremePowerOuters's Avatar
Default Lowering Spring or Coilover
Hey guys, I want to know your opinion. Let me know what you think I should go with, thanks.
Old Aug 9, 2004 | 09:02 AM
WRS2K's Avatar
Ground Control.
They use Eibach race springs and you can pick out the rates you want to match with the stock shocks (assumption).
I've been running the 340F/380R setup for a good 30K+ miles (lowered 1.5") and the car feels just as good as day 1. Once the damn good stock Showas start showing their age, I'll probably end up with Koni Yellows and call it a day.
FYI, 99% of my driving is done on the streets.
If I ever decide to step it up another level, I'd bypass the typical JDM coilovers and end up with Ohlins sold through Comptech and s2ki.com.
Good luck with your decision.
Regards,
Old Aug 10, 2004 | 12:05 AM
evil vapor's Avatar
Default Re: Lowering Spring or Coilover (ExtremePowerOuters)
how often do you plan on adjusting the height of the coilovers? how often do you see yourself testing out new spring rates? adjustable spring perches on coilovers are there for more than adjusting the ride height of the car, in fact their pupose is for tuning with different spring rates not really height adjustability besides corner balancing.
Old Aug 10, 2004 | 06:38 AM
Razor's Avatar
Default Re: Lowering Spring or Coilover (vapor)
go with kg/mm supersports and koni yellows, you'll love it. perfect for a street car.
Old Aug 10, 2004 | 06:42 AM
Default Re: Lowering Spring or Coilover (Razor)
What are kg/mm supersports?
Old Aug 10, 2004 | 07:17 AM
AWD: Jeff's Avatar
there i think springs that are really stiff in ride quality, at least mine are. http://bulletproofautomotive.c...D=126
i have the kgmm race springs with the koni's yellows. i have no complants. all though i wouldnt mind tradeing them for coil overs, that it gc or comptech.
Old Aug 15, 2004 | 03:44 PM
J'sRacing's Avatar
Ohlins
car1115
Suspension & Brakes
21
Mar 24, 2012 07:44 PM
92integraVTECgsr
Suspension & Brakes
Nov 22, 2005 10:44 PM
BrandonClaps
Nov 7, 2003 10:36 PM
Leb_CRX
Sep 15, 2002 05:10 AM
fiebru1119
Apr 23, 2002 07:35 AM
