Valve Clearance
Old Aug 8, 2004 | 07:18 PM
gamakichi77's Avatar
Default Valve Clearance
i'd just did do an clearance for my valve. engine B16A with all stock internals.
i tight it with HONDA specs.......
but, when i start the engine, it still creating a sounds which is not good.....some of my friends told me that, it could be springs under vtec lobes are not tightened well.....who can tell me whereabouts of this springs?......so that i can tight it now......
Thanks.
Old Aug 8, 2004 | 09:12 PM
OTT's Avatar
OTT
If your friend meant the 'LMA's (Lost Motion Assemblys) then theyre little springs underneath the central rocker arm. You canttinghtn them though, you just have to replace heavily worn ones.
If its more like a fast clunkng then it is likely to be a rod bearing.
Old Aug 8, 2004 | 10:00 PM
Default Re: (OTT)
thanks for your reply man......is it rod bearings?......coz i heard the sounds was came out from the head itself......
how can i replace the worns of LMS?........any articles where can i get the step-by-steps of doing it?.......
blasta510
17
Dec 19, 2011 11:17 AM
VtecLsEater
Feb 27, 2009 11:02 AM
vtecn8ive
Oct 6, 2006 07:14 PM
aaronhume
Mar 7, 2006 06:17 PM
turborex
Feb 17, 2003 05:22 PM
