Rusting out?
Old Aug 8, 2004 | 06:30 PM
AccordCD5's Avatar
Default Rusting out?
A couple of years back my I took my 5th gen in for new rotors and brake pads. I was told that the frame underneth my car had a good deal of rust attached to it. My accord was previously from northern Pennsylvania where snow is plentiful durring the winter months. So salt deposits were the culprets for this. My question is before I were to start spending some big $$ on the car is there anyway to fix this problem? or am I screwed? I will have it checked out in about a month by a diffrent mechanic when inspection is due. Thanks
Old Aug 8, 2004 | 07:01 PM
PhatboyNYC's Avatar
Default Re: Rusting out? (AccordCD5)
It really depends on exactly where the rust is and how severe the problem is.
Old Aug 8, 2004 | 07:11 PM
fw190bvi's Avatar
Default Re: Rusting out? (PhAtBoY Si)
during the winter, i take my car to the coin car wash nearly once a week.......powerwashing the undercarriage gets out all teh salt and the impacted slush and stuff......if its not bad, it could be sanded down to fresh metal, and then recoated with that **** they spray on down there
Old Aug 9, 2004 | 07:07 AM
arkytec's Avatar
i think your best bet is to sand it down and then have it recoated, that might be the only thing you can do if you are planning on keeping the car for some time, it will be costly, but once you sand it down and they coat it again, you might even be able to get it coated with something more heavy duty
TypeR324
Honda S2000
Sep 27, 2007 06:51 AM
satsilprelude
Aug 30, 2006 05:17 PM
klomast3r
Jan 30, 2006 11:10 PM
J blunted
Aug 4, 2005 11:45 PM
Veil_Side_
Feb 11, 2002 06:55 PM
