How's this for nasty welding and an imagination?
http://forums.vwvortex.com/zerothread?id=1189976
Off the honda topic but I think it's pretty bad -***!
Maybe I'm not catching something, but why does he have flex pipes on the dump tubes? I dont see how any thing on that TT manifold is going to shift?
Looks good, but sure hope he has some well designed/effective braces to support that!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamCracka »</TD></TR><TR><TD CLASS="quote">Maybe I'm not catching something, but why does he have flex pipes on the dump tubes? I dont see how any thing on that TT manifold is going to shift?
Maybe it has something to do with thermal expansion...since the dump tubes will be changing temperature alot more and differently then the manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXMan »</TD></TR><TR><TD CLASS="quote">
Maybe it has something to do with thermal expansion...since the dump tubes will be changing temperature alot more and differently then the manifold.</TD></TR></TABLE>
Thats what corky bell has to say about that.
"The flex is there to help in the installation of the system. You try to get 4 points to line up. If it was possible to line everything up easily then there would be no flex sections. The street exhaust will have a flex section right after that collector. Also, i dont expect too much movement in the engine. It will have all poly mounts and i am going to cut the poly in half and make half of it metal. We thought about making flex sections in each downpipe but there was not enough room anyway."
bunburyd16y
Southwest
25
Oct 30, 2007 11:01 PM
