ITR rear sway bar + Neuspeed rear lower tie bar??
I don't know about that one. There was a thread on this a while ago though....
I know the Comptech (look at the design!), and the Benen ones work though.
You can if you can get a longer bolt to go through the neuspeed tie bar and a spacer otherwise it hits the bracket of the ITR rear sway bar. An easier way would be to get either a benen or comptech.
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Just get some spacers, ie - washers, to install between the subframe and the bar and you should be able to fit the bar. I've done it with my friend on his car.
you'll need to replace the bolts that comes with Neuspeed with another bolts that is an inch longer
then get a 1/2" spacer...
that's it.
that's it.
I got mine to fit without buying additional hardware but I would definately not recommend this combination. The two bars nearly touch at some points and in order to get at the sway bar brackets you have to remove the neuspeed bar.
I say go with the benen bar. Easier install and does not cost that much more.
what about a DC lower rear tie bar? same logic apply here?
my ITR rear sway is on its way, and I was told that I would just need longer bolts and maybe another spacer/washer
i tried bolting up a generic lower tie bar onto my teg with a ITR lower sway bar and it wouldent fit. the mounting brakets of the tie bar would hit the ITR mounting brakets......maybe the neuspeed tie bar is a diffrent and will fit?
