SOHC head gasket on ZC?
No I have DOHC brown top ZC, but I want to use a metal headgasket and their seems to be a lot available for the SOHC d's but only one for the DOHC.
Screw you guys, I'm... going... home.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxhybrid85 »</TD></TR><TR><TD CLASS="quote">No I have DOHC brown top ZC, but I want to use a metal headgasket and their seems to be a lot available for the SOHC d's but only one for the DOHC.</TD></TR></TABLE>
Sorry, but DOHC <== different head bolt pattern ==> SOHC, however it is only 1 bolt hole that is off. I have no idea about the oil/water passages. Just go to an auto parts store or dealership and ask to look at both a SOHC and DOHC head gasket. Line them up and see how they match. If it's all good except for the one head bolt hole, then a file/drill/dremel should take care of it. If it works, share the info and post up to let us know. You'll be an H-T tech god, yO!
BSM_89Si
Jul 28, 2010 10:38 PM
Gumbey75
Feb 28, 2005 06:17 PM
