putting in springs
Old Aug 8, 2004 | 02:58 AM
jadugartir's Avatar
Default putting in springs
Tonight i put my car up on blocks, removed the wheels, im ready to start putting in my new eibach pro-kits, getting rid of my front cut springs tomorrow. so i was looking at how everything goes together. what bolts am i gonna take out to drop out the strut so i can put new springs on it. Im also replacing my drivers side uca and ball joint. I was wondering how to take it all apart so i can put all the new stuff in
Old Aug 8, 2004 | 07:24 AM
jadugartir's Avatar
Default Re: putting in springs (jadugartir)
bump, id appreciate a diagram or anything... I figure im gonna undo some of the bolts in the engine bay and then the whole strut assembly should drop right out... am i correct?
Old Aug 8, 2004 | 07:52 AM
Synth124's Avatar
I own a 91 crx dx, so you should be in the same boat.
Front Struts: Undo the bolt that connects the fork of the strut to the lower control arm. Then that fork that you just disconnected from the control arm, there is a bolt on the back side of it, remove that bolt. Next you have to remove that fork completely, shouldn't be too annoying to do. Just twist it a little and I'll come off the strut. After that in the engine bay locate the two nuts that hold the strut in place. Remove those and the strut will come right out.
Upper Control Arm: It's simple unbolting and bolting, just look you'll you get it. If you can do the strut job the upper control arm is a cake walk.
Old Aug 8, 2004 | 08:04 AM
jadugartir's Avatar
thanks, im pretty sure i see how its gonna come off now... so im gonna drop the whole strut out, replace the springs, then put it all back in reverse order, starting with the lower arm
Old Aug 8, 2004 | 08:13 AM
jadugartir's Avatar
Oh yeah one more thing rear struts, i havent taken my wheels off the back yet so im not sure how that assembly works... what am i gonna undo to get the strut out.
Old Aug 8, 2004 | 08:35 AM
tilt's Avatar
not your car but the steps are very similar.
http://internet.cybermesa.com/....html
Old Aug 8, 2004 | 08:45 AM
jadugartir's Avatar
Default Re: putting in springs (tilt)
Also,when i take stuff out i want to clean it because up under my wheel well, all the parts are real grimey and sick looking... Im replacing some but the rest when its taken apart i figure ill clean it... and the wheel well itself im not sure if some of it is insulation or whatever, or meant to be there, but i live in texas where you dont have to worry about salt on the roads and you can drive your car 12 months of the year.
What works to make that stuff look less grimey... I have some "gunk" but thats for engines... and i have this concentrated orange extract super cleaner **** that i know would dissolve all that ****... but i dunno if i should use that.
si_motor_spt
12
Jun 17, 2010 07:35 PM
cj98gs
May 24, 2009 08:21 PM
Midori Green
11
Jan 25, 2007 07:22 PM
89 CRX SI
17
Jul 15, 2002 10:21 AM
