ls pistons in b16 for boost
Old Aug 7, 2004 | 08:55 PM
turboekcivic's Avatar
Default ls pistons in b16 for boost
i wanna put ls pistons in my b16 and i was wondering if it is possible to do it..
i dont know if the valves will hit the pistons.. i dont wanna boost on high compression b16 pistons.. alittle help plz
Old Aug 7, 2004 | 09:20 PM
leed's Avatar
Default Re: ls pistons in b16 for boost (turboekcivic)
Ive used US ITR's in my B16 to get 9.7:1; and Im currently using P72's for 9.0:1.
IMHO LS pistons might be a tad bit low. C-Speed compression calc is down right now, but if I remember right LS in B16 will yield around 8.5:1. A bit too low IMHO.
I didnt notice any part throttle/off boost difference when at 9.7:1, but at 9:1 it is deff. noticable. Part throttle is no longer snappy, and WOT at 0" vacuum is down on power. I am currently boosting 15psi through an SC61 on the P72 pistons right now, and all is well.
FYI, your B16 rods will not fit into ITR's or P72's with out machine work. I elected to have material taken off the pistons instead; and balanced them afterwards.
Goodluck
Old Aug 7, 2004 | 11:18 PM
m R g S r's Avatar
Not worth it, if your gonna swap pistons, then save up and buy some forged ones.
Old Aug 8, 2004 | 01:25 PM
Default Re: ls pistons in b16 for boost (m R g S r)
so i should use p72 i wont be able to afford forged im only 17 on a budget,
evilclown312
Jul 12, 2012 08:13 PM
bens_redeg
Mar 17, 2004 03:26 AM
JBk24crx
Jul 30, 2003 10:28 AM
turbohf
Jan 22, 2003 01:48 AM
