MC (Master Cylinder) Swap ?
Alright, everyone my MC went out. Well, that is mine and a friend's conclusion. To make a long story short - my brakes went out omw home from work. I took apart my rear drums and the left wheel cylinder was gone. Well, we changed the rear shoes, the left wheel cylinder and had the drums shaved down. We bled the crap out of the brakes both front and back to get proper pedal feel you know but after a few countless attempts at bleeding the brakes and 2 test drives it maybe got about 5% better feel. We practically went through a quart of brake fluid.
I have a 90 Honda Civic Dx for the infor. Can you guys just reasure me my questions ? I searched and everyone says something different. I also have DA front brakes.
A) Well, I know that the EX 4 dr MC is a direct bolt on to my booster with no rebending of lines?
B)Also, I know the 89 accord lxi is a direct bolt on too but you have to rebend the front line ?
C) Also, the 88-91 2.0 SI prelude MC bolts on directly too but you have to rebend the front line as well ?
Good Day,
RH.
Good Day,
RH.
I had a 90-93 Integra MC and Booster. Get the MC and booster. Big MC pushes more fluid and big booster allows more pressure with less effort. A winning combo.
it is really up to u but if u ain't going to change out the booster also then just stay stock....
and if u going to upgrade the motor then get the DA combo
if u want a stock one I have two MC's and one booster
as I installed the ITR in my project but have a extra one as I change one for a friend for the lude one but didn't feel that much of a difference expect the locking up is a bit easier to do now
Anyone Esle ? Someone that has had any of the above MC's ?
Did you have the rebend the brake lines with the DA MC and booster ? How much bending was needed ?
Good Day,
RH.
Good Day,
RH.
Check out Driven's write up, http://thezam.org/kam/ (it's under 'Tech'...).
Also found here, without pics,https://honda-tech.com/zerothread?id=456037.
I prefer the simple 15/16" setup. The 1" Integra MC, requires a bit more work. And its only 1/15" more. That's not much. Plus it may get in the way of some aftermarket strut bars.
I have braces for the 15/16" MC too.
See sig.
See sig.
I have the 15/16" DA master and booster. The lines bolt right up, no bending or new flaring required. But, if you still have DPFI, you will have to unbolt the intake manifold to get the big booster in there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eggman »</TD></TR><TR><TD CLASS="quote">I have braces for the 15/16" MC too.
See sig.</TD></TR></TABLE>
AWESOME BRACE
See sig.</TD></TR></TABLE>AWESOME BRACE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egturbohatchback »</TD></TR><TR><TD CLASS="quote">
A) Well, I know that the EX 4 dr MC is a direct bolt on to my booster with no rebending of lines?</TD></TR></TABLE>
A) The 90-91 EX M/C & booster will move over to the other Civics of the same generation as a unit. Strictly a bolt-on affair with no mods required.
Well, everyone I just ended up getting an 88 accord lx-i MC at a local junk. Direct Bolt on - No Problems with lines or anything. Now, I just have to bleed my lines and ride.
Good Day,
RH.
Good Day,
RH.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eggman »</TD></TR><TR><TD CLASS="quote"> Plus it may get in the way of some aftermarket strut bars.
"Rat bastard stinking frazzle brat cheese chicken poopy stink rotten coward freak."
- toned down quote of Me after I trying fitting my brand new strut bar on with the ITR MC and booster.
ITR MC : 1
Strut bar : 0
ITR MC : 1
Strut bar : 0
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF »</TD></TR><TR><TD CLASS="quote">
ITR MC : 1
Strut bar : 0
Double this !!!!!!!!!!
But I moded mine to work but still ......
IT sucks but Itrather have better braking then a strut bar can always get a neuspeed or something
ITR MC : 1
Strut bar : 0
joprez
May 7, 2013 02:54 PM
y49crxsi
Jul 16, 2004 02:14 PM
