Are used cams ok???
Old Aug 7, 2004 | 05:58 PM
ItalynStylion's Avatar
Default Are used cams ok???
Someone wants to sell me some crower stage2 cams, valve springs and titanium retainers. He says that they have 7,000 miles on them. I dont really know much about cams and the type of abuse that they take. So i guess what im saying is do cams wear out, is there anything bad i should look for when im buying used cams?
Old Aug 7, 2004 | 07:52 PM
TxTuner
Guest
Posts: n/a
Default Re: Are used cams ok??? (ItalynStylion)
99% of engines out there use 1 set of cams thier entire life span. If properly maintained and tune-ups are performed as required, those same engines will also lose very little performance over it's life. To put it simply, 7000 miles on a set of cams is not enough time to put significant wear on them. If the price is right, I would say go for it and always under bid what they ask, remember the parts are used. good luck
Old Aug 8, 2004 | 12:39 AM
jdmcivicferio's Avatar
find out what year the cams were made, and look for external damage on them, the first batch of crower cams were not very good and cracked a lot but there new batches are very good
realis9
May 21, 2007 04:55 PM
realis9
May 20, 2007 01:20 PM
realis9
May 20, 2007 12:15 PM
realis9
May 17, 2007 01:32 PM
