turbosmart wastegate/Turbo XS dual-stage MBC install. questions inside:
Old Aug 7, 2004 | 04:48 PM
kaj's Avatar
kaj
Default turbosmart wastegate/Turbo XS dual-stage MBC install. questions inside:
i've searched current and recent,
i've checked every website i can think of.. and i cant figure out one small thing:
how to install my MBC !!!
on my old car i just put the MBC in the vacuum line between the compressor side of the turbo and the wastegate.
but NOW i have a Turbosmart wastegate with TWO nipples, and the nipple on the bottom of the turbo is in a bad spot. if i connect the WG and turbo, the vacuum line will run too close the the exhaust mani.
so is there another way to run it? my Tial only had one vacuum nipple i don't know what the two on my Turbosmart are for.
if anyone can tell me, or direct me to a site with instructions, that would be helpful. thanks!!
Old Aug 7, 2004 | 05:07 PM
HYBRID_H@TCH's Avatar
Default Re: turbosmart wastegate/Turbo XS dual-stage MBC install. questions inside: (kaj)
its easy..
run a line from the gate(lower hole or bottom hole) to the turbo..
put a vac T in that line in the easiest to get to spot..
run an hose from that T to the "in" or -> on the MBC..
then run a line from the out side of the MBC to the top of the gate..
DONE.
Old Aug 9, 2004 | 12:35 PM
kaj's Avatar
kaj
Default Re: turbosmart wastegate/Turbo XS dual-stage MBC install. questions inside: (99Hybrid_Hatch)
maybe my boost controller is busted.. 'cause that doesn't seem to work
Old Sep 5, 2004 | 05:22 PM
kaj's Avatar
kaj
just got an im from someone regarding this post. soooo, i should update:
i had the vaccum lines running the wrong way. surprise, surprise.
sorry for the mixup and thanks, david.
leinadmiih00
Jan 20, 2007 04:58 PM
sykotic
Dec 4, 2004 09:49 AM
B18 CYA
Aug 5, 2004 10:01 PM
Turbo88Lude
Oct 30, 2003 10:13 PM
VanHonda
Jun 8, 2003 04:01 AM
