JDM Distributors...
Old Aug 7, 2004 | 03:26 PM
Jintegra99's Avatar
Default JDM Distributors...
Considering purchasing a product from Distributor King, but the application for my car (99 GS-R, OBDII) is a JDM one. It reads:
96+ DOHC Civic SI, Integtra Type-R & GSR, JDM OBDII "B" Series
Part#:TD84, TD81
Description: Compatible With OEM# TD81U, TD84U, TD86U & TD87U
· 96+ GSR
· 96+ Type-R
· 96+ Civic Si W / “B” Series Engine
Should i have any problems installing this? Will it bolt right on?
Old Aug 7, 2004 | 05:43 PM
Jintegra99's Avatar
Default Re: JDM Distributors... (Jintegra99)
no one??
Old Aug 7, 2004 | 06:26 PM
Deep's Avatar
any 96+GSR Distributer should fit your car, the engine harnesses are bascilly the same you should be aight, if you had a pic of the plugs I would be able to tell.
Old Aug 7, 2004 | 09:20 PM
jmk2888's Avatar
It should fit, Dist. King is in my book.
The rotor that it comes with it does not have a screw hole/screw but you can buy a OEM Rotor and will screw on fine.
Also if you have MSD, the MSD cap will not fit w/o modification.
Old Aug 7, 2004 | 10:18 PM
Jintegra99's Avatar
Default Re: JDM Distributors... (jmk2888)
Thanks guys for the replies. Yeah i've read that the rotor that comes with the Dist. King doesn't have a screw and can simply be yanked by force of hand. I don't get it though...will i need a new rotor cuz the one supplied isn't good enough? Or were you just talking about something I might have to do later?
And nah i don't have MSD ignition, nor will i probably for a while, seeing as my car is bone stock
Old Aug 7, 2004 | 10:55 PM
jmk2888's Avatar
I would personally get a OEM rotor and screw instead of the Dist. King's
That 's just me.
For my ITR motor, it's like $18.95 at Acura.
h22Hatchy
Aug 28, 2004 09:13 PM
b18c1_powered_si
Mar 17, 2004 01:21 PM
