spark plug wires
my question is.. are there any differences between stock spark plus wires and ones with bigger diameters? do u really get hp gains? (i kno not to believe most things on ebay), but sumone has told me that too... so i was just curious.
heres the spark plug wires im looking at. >>http://cgi.ebay.com/ebaymotors/ws/eB...category=33692 <<
do u think those are real JDM wires? and is 10.2mm bigger than stock? sorry for the noob questions. but i'd like to know once and for all. :D
thanks for reading.
thanks for reading.
Just make sure they are spiral wound non-interference. But you will most likely on a healthy engine not get any gains. Probably a better idle at best.
Try NGK wires. I think they are best. Email nvthai@msn.com for better prices than sponsors. Tell him James recommended.
Guest
Posts: n/a
Accel wires are ****!
If your going to spend any less than $75 on a set of wires, you'll be replacing them within a few months due to internal breakdown of the wires. MSD on the other hand is a pretty good wire but I'm still going to have to say stick with oem.
ive been sporting magacore wires for like 2 yrs now, did not notice much but a tad smooth idle. Only reasion i replace mine was FLA weather, Ill swap them out again next yr
hmm.. alrite. thanks for the input. i guess i wont be getting those anymore.
do u kno where to get oem lips? haha like the whole set. not juss the front.
I've got NGK iridium plugs, magnecor wires, MSD SCI ignition, and a Blaster SS coil. I've had them for two years and never had a problem. All together it did give some power. I wouldn't get wires unles you plan on runnin an MSD and Coil, it'll help in conducting the current to make larger, multiple sparks. It does help in burnin fuel, the more you burn the more power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kriptik »</TD></TR><TR><TD CLASS="quote">I jus ordered the nology wires, n e body kno if they r good?
ya but theres someone on po.com selling them slightly 3 months used cheaper, id cancle ur order and contact him
There is a spark plug wire dyno test floating around the net from a few years ago. The tested several "high performance wires" against the 9 yr old OEM NGK's that were on the vehicle.
None of the aftermarket wires gained any hp over the stock, in fact the OEM wires put out 1 whp more then the aftermarket wires.
My adivce, get some NGK's and call it a day.
Modified by Behan at 4:55 PM 8/16/2004
From: united states of mexico and yes ladies i am, available
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerx »</TD></TR><TR><TD CLASS="quote">Tuner Product Review did dyno tests a few months ago on a turbo Civic. The Ones with biggest increase were MSD and Accel. MSD= +3.8hp and Accel= +1.8hp.</TD></TR></TABLE>
do u mean import tuner cuz i remember the msd made most power and the fit sucked cuz they had to use zip ties and ngk was 2nd in power gains and best in fit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Behan »</TD></TR><TR><TD CLASS="quote">My adivce, get some NGK's and call it a day.
x2
x2
i bought some 10.2 mm
thick wires for my sol and those things were great i had a smoother idle and faster accleration over all they were high quality over the stock 7.2mm
wires
wires
here is the dyno test i was talking about.
http://www.vtec.net/articles/v...=8680
although they reference NGK vs OEM, NGK is the manufacturer of OEM honda wires, IIRC.
I use wires from Wires4cars.com on both my honda street car and my BB vw beetle drag car.
BTW.....why did twoody get banned(a banner advertiser and owner of Wires4cars)from hondatech for giving advice? take the money and ban
