Cylinder heads, please help!
Old Nov 29, 2001 | 12:13 PM
evo's Avatar
evo
New User
Default Cylinder heads, please help!
Just replaced head gasket and valves spring by local garage, after a week, i saw radiator expansion tank has mayoniase like 'gloop'. My friend just told me (indicates cylinder head problems), Is it true any idea of what coz that problem, please help.
Is B16A engine.
Old Nov 29, 2001 | 05:37 PM
evo's Avatar
evo
New User
Default Re: Cylinder heads, please help! (evo)
Is it due to incorrect gasket fitted, also the temp higher than before gasket fitted, i believe someone must know. please reply!
Old Nov 29, 2001 | 10:34 PM
fo-do's Avatar
New User
If you replaced the head gasket with a thinner one, then that may be the cause of your temperature rising, because of a slight increase in compression.... unless it's alot higher... then something's not right.
Are you sure the garage put the right gasket in??? if not, you're gonna have serious problems... like if they put in a gasket from a 1.8L LS motor? It will fit but there are holes in the VTEC gasket that allow coolant and oil through that are not present on the LS gasket...
Other than that, i don't know what else it would be... has nothing to do with the valve springs, i know that much for sure...
Wish i could tell you more... either way, you're gonna have to pull the head to know for sure.... good luck!
Old Nov 30, 2001 | 12:48 AM
oOxsboostOo's Avatar
New User
Default Re: Cylinder heads, please help! (fo-do)
what was the point of the head gasket?
were you raising the compression ratio (already at 10.4:1)
why just valve springs... not retainers or stainlesss valves.
have you brought this to the shops attention?
by determining what they tried to sell you, and why, it might be possible to figure out if these guys were even qualified to take your valve cover off...
Old Nov 30, 2001 | 11:19 AM
evo's Avatar
evo
New User
Default Re: Cylinder heads, please help! (oOxsboostOo)
Thx for advice first. The gasket replaced is normal 0.7mm, just wonder is B16A and non Vtec 1.6 Si has the same gasket or not? If so i think they may put a wrong gasket on!
Old Nov 30, 2001 | 12:25 PM
Mugen Dom's Avatar
u need a b16 head gasket than the there is no non vtec b16 the no vtec si is a d16
Old Nov 30, 2001 | 03:54 PM
evo's Avatar
evo
New User
Default Re: Cylinder heads, please help! (jdmB18hatch)
So is B16 and D16 use the same gasket???
Old Nov 30, 2001 | 04:57 PM
asnx6pac's Avatar
NO!
Old Nov 30, 2001 | 05:55 PM
fsarfino's Avatar
Default Re: Cylinder heads, please help! (asnx6pac)
if you look on the left side of the engine there should be a piece of the gasket hanging about 1/4" from the edge of the head it will have a code on there it should say PR3 on it maybe there are some extra #s but it should have pr3 on the gasket and I hope that shop rembered to but your dowl pins back in also. BTW does the coolant appear oily
Old Nov 30, 2001 | 06:34 PM
evo's Avatar
evo
New User
Default Re: Cylinder heads, please help! (dohcvtec16)
Yes it does, the coolant appear oily, there're some yellow stuff floating. It doesn't exist b4. I try to take the pic of it 2morrow!
erikwithak
Jul 17, 2009 01:15 PM
crx-neo
Nov 6, 2005 10:16 AM
jmcclell
Sep 14, 2004 04:07 PM
tegmaniac
Apr 24, 2003 11:20 AM
S13 slide
Jan 4, 2002 06:20 PM
