Quick Question ASAP, Please!!
Old Nov 29, 2001 | 11:51 AM
evo's Avatar
evo
New User
Default Quick Question ASAP, Please!!
Just replaced head gasket and valves spring by local garage, after a week, i saw radiator expansion tank has mayoniase like 'gloop'. My friend just told me (indicates cylinder head problems), Is it true any idea of what coz that problem, please help.
Is B16A engine.
Old Nov 29, 2001 | 11:58 AM
RyanR's Avatar
Default Re: Quick Question ASAP, Please!! (evo)
White sludge means you have a blown headgasket or it's leaking. Take off you oil fill cap and check if you have any of that white goop on the bottom of it.
Old Nov 29, 2001 | 12:09 PM
evo's Avatar
evo
New User
Default Re: Quick Question ASAP, Please!! (97TypeR_9)
No, those gloop are yellow and only find in radiator.
Old Nov 29, 2001 | 05:32 PM
BreakStuff's Avatar
New User
That "gloop" could be residual goop that was in the system prior to the head job... If the coolant wasn't fully flushed then the oil compounds would still be found in the coolant.. is a coolant flush done when the headgasket has been replaced??.. not usually..
pepperdk
Honda CR-V & Element
Mar 23, 2015 03:37 AM
xpdude
28
May 3, 2010 02:33 PM
futurefastguy
May 2, 2009 10:33 PM
CNSK
Sep 7, 2005 06:33 AM
1strdtko
Apr 27, 2003 05:27 PM
