Oil leaking out of Turbo exhaust side?
Old Aug 7, 2004 | 09:45 AM
IvanB's Avatar
Default Oil leaking out of Turbo exhaust side?
just recently installed and have been breaking in system...
i have a small exhaust leak i need to fix, but i just noticed oil leaking from turbo...
anyone have any idea whats causing this, and how to fix?
my engine bay...
http://thebohannongroup.com/img/100_4858.JPG
the problem...http://thebohannongroup.com/img/100_4853.JPG
http://thebohannongroup.com/img/100_4854.JPG
http://thebohannongroup.com/img/100_4855.JPG
top view of turbo exhaust manifold leaking oil...
http://thebohannongroup.com/img/100_4857.JPG
my crappy rigged oil feed line...gotta get a new one.
http://thebohannongroup.com/img/100_4859.JPG
thanks much,
Ivan
p.s. turned images into links to make it easier to read
Modified by IvanB at 7:35 PM 8/7/2004
Modified by IvanB at 1:35 AM 8/8/2004
Modified by IvanB at 1:36 AM 8/8/2004
Modified by IvanB at 1:37 AM 8/8/2004
Modified by IvanB at 1:40 AM 8/8/2004
Old Aug 7, 2004 | 10:09 AM
Endless's Avatar
Default Re: Oil leaking out of Turbo exhaust side? (IvanB)
Check for shaft play. My turbo did the same thing when the center section went to ****.
Old Aug 7, 2004 | 10:25 AM
IvanB's Avatar
Default Re: Oil leaking out of Turbo exhaust side? (Endless)
Hmm brand new turbo from ss autochrome. before installing shaft play was zero.
i had to rotate the compresser and inlet sides, maybe that messed something up?
Old Aug 7, 2004 | 10:38 AM
InJ3cted's Avatar
Might be ur oil return line.. .. seems like you have a kink in the line that could cause the oil to build up and creep past the seals , if u don't fix it then the seals will go bye bye Is it smoking blue at all?
Old Aug 7, 2004 | 10:55 AM
Blackack26's Avatar
Default Re: Oil leaking out of Turbo exhaust side? (InJ3cted)
I think the return line might have something to do with it
Old Aug 7, 2004 | 11:10 AM
civictypenos's Avatar
Default Re: Oil leaking out of Turbo exhaust side? (Blackack26)
to big of feedline or something wrong with return line.i had the exact looking problem before i replaced the feed line and re routed the return line.
how low is your retun line plumbed into your oil pan?
Old Aug 7, 2004 | 01:38 PM
wade's Avatar
Default Re: Oil leaking out of Turbo exhaust side? (civictypenos)
mine is like that too, due to a ******* oil pump that pumps oil from HELL, its way to high PRESSURE. my trubo smokes hella bad, damn seals
Old Aug 7, 2004 | 03:32 PM
turboekcivic's Avatar
Default Re: Oil leaking out of Turbo exhaust side? (wade)
its ur oil return i think.. seals are busted
Old Aug 7, 2004 | 04:35 PM
IvanB's Avatar
Default Re: Oil leaking out of Turbo exhaust side? (turboekcivic)
I replaced my oil return line with an Oil rated hose ( no more heater hose), shortened the hose up, and now it runs smooth from turbo to oil pan, without any kinks.
my question is, whats gunna happen to all the oil that over ran into the turbo compressor side?
can i just drive it off and pray or do i need to remove the turbo, open it up and clean all the **** out?
thanks for advice. never ran into this problem before.
oh btw the turbo has less than 3 hours of drive time on it, and probably 60 mins or less with the oil coming out of it problem -- since i check the system after each drive.
Old Aug 7, 2004 | 07:18 PM
CRX T-Si's Avatar
Did anyone bother to look at the engine bay pic carefully???
If you look at the stock intake hose you will see that the Valve cover vent is connected to the intake hose that is connected to the TB.
That is a big no no.
Your pressurizing your engine the wrong way. That vent needs to vent not pressurize.
I'm surprise that it actually boosted at all like that.
U need to fix that Oil feed before it breaks from vibration.
Here is the topic that was discussed earlier https://honda-tech.com/zerothread?id=946473
NEAL FRISBIE
Jul 8, 2011 03:55 PM
TurbojdmEG93
Mar 13, 2010 04:14 PM
smoovy
Mar 28, 2009 10:02 PM
malubawla
Jul 18, 2007 08:02 AM
riceburnah
Dec 6, 2003 02:06 PM
