engine problems!!help A.S.A.P please!!!!!
Old Aug 7, 2004 | 06:59 AM
vaporboy12's Avatar
Default engine problems!!help A.S.A.P please!!!!!
ok heres the problem my car started making a loud clanking noise. so i thought it was rod bearing. i replaced rod bears, oil pump water pump timing belt. and checked the main cap bears those were ok. put everything back together. started it up still clanking. did a compression test. from timing belt side it went 155,152,151,80 so i started to pull the head but want to know would it be a valve bent problem or a piston problem?
thanks
Old Aug 7, 2004 | 07:50 AM
Chiovnidca's Avatar
Default Re: engine problems!!help A.S.A.P please!!!!! (vaporboy12)
A leakdown test will answer your question.
Old Aug 7, 2004 | 08:34 AM
vaporboy12's Avatar
Default Re: engine problems!!help A.S.A.P please!!!!! (Chiovnidca)
i just pulled piston 4 cause thats were the noise sound like it was coming from and the noise sound is coming from the trans when i rotate the crank by hand
HLvet
Dec 8, 2014 05:02 PM
jayare05
Nov 11, 2008 01:39 PM
fryman
Aug 22, 2008 10:31 AM
fadedline
Mar 23, 2007 03:10 PM
-slow ej-
Feb 26, 2004 09:38 AM
