Problem wiring B16 distributor into Si CRX harness - engine conversion
Old Aug 7, 2004 | 03:37 AM
JohnCRX's Avatar
Default Problem wiring B16 distributor into Si CRX harness - engine conversion
I am up to rewiring the new B16 with my old D16 CRX harness and have struck problem.
Everything seems to connect up to the old harness OK except the distributor.
The old motor at the distributor had a rounded plug with 2 wires plus a larger rectangular plug with 5 wires (out of possible 6).
But trying to connect to the B16, the new distributor has the same rounded plugs with its 2 wires plus very large rounded plug with 7 wires!
I thought the harness was supposed to connect right up then add the 4 extras for the vtec?
Can you help me out here, what to do with the 7 wires plug????
Old Aug 19, 2004 | 01:56 PM
LoooseGSR's Avatar
Default Re: Problem wiring B16 distributor into Si CRX harness - engine conversion (JohnCRX)
what color are the plugs on the distributor
Old Aug 19, 2004 | 08:32 PM
lemongreenhatch's Avatar
Default Re: Problem wiring B16 distributor into Si CRX harness - engine conversion (PSUCRX)
is it obd0 distributor
Old Aug 20, 2004 | 08:21 AM
Cnote's Avatar
sounds like a DX Dizzy
5 wires on square plugs
2 sensors(total of 4 wires)
1 ICM (one wire)
elmalouno
Apr 11, 2009 04:48 PM
racing27
May 1, 2008 08:30 AM
robbizza
Nov 29, 2006 04:01 PM
SPITVENOM67
16
Feb 14, 2006 12:57 PM
Dainbramage
Jun 28, 2004 03:42 PM
