92 civic tape deck help
hey guys ive got a 92 lsi civic and its got the original panisonic tape deck in it. wot i want to do, for now, is hook up two back speakers up to it. but at the back of the deck theres a plug with the wires and i dont av a clue where to hook the new speakers to, any help wud be gr8.
loz
loz
When you pull the radio out, you should look for these wires at the plug:
Right rear speaker (+) = red w/yellow stripe
Right rear speaker (-) = brown w/ white stripe
Left rear speaker (+) = blue w/ yellow stripe
Left rear speaker (-) = gray w/ white stripe
See if you can find these wires in the rear deck of your civic, if not, follow them from the radio and do the correct connections.
Good luck!
Good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grease_monkey1986 »</TD></TR><TR><TD CLASS="quote">hey guys ive got a 92 lsi civic and its got the original panisonic tape deck in it. wot i want to do, for now, is hook up two back speakers up to it. but at the back of the deck theres a plug with the wires and i dont av a clue where to hook the new speakers to, any help wud be gr8.
loz</TD></TR></TABLE> Honda/Acura run all the speaker wires even if they don't install rear speaker, so just look around where the oem rear speakers go and you will find the rear speaker wires with a plugs on the end of them, they will be taped to other wires at the plug.
94
94
bee743
14
Feb 26, 2012 12:13 PM
cnowak
May 24, 2011 09:38 AM
Jizzmaster Zero
May 19, 2006 09:42 PM
