is this oem or aftermarket shift knob?
Old Aug 6, 2004 | 10:26 PM
cxSHOE's Avatar
Default is this oem or aftermarket shift ****?
not sure if this is an oem honda/acura **** but this came off a jdm eg6, it doesnt look like a factory **** that i have ever seen, but has the distinct red stitch like the factory red stitched *****, 5 speed with reverse all in the correct pattern as a honda/acura cars. and has the correct shifter thread pattern ( thread pattern for the actual shifter) also and fits fine on the shifter nice and snug. just wondering if anyone else has seen this type of ****. my cousin in japan has had no luck on its whereabouts either. thanks for any help you can provide. would like to get some info on it before it is sold. it is a jdm **** so no usdm **** will be the same as far as i have seen. just wondering if anyone has seen it before?
my conclusions so far:
1. its not a usdm 97 itr or prelude optional **** these had the red stitching along the front and rear of the **** > this one stops on the backside.
2. its not a usdm or jdm ep3 si/type r **** because the usdm ep3 has a rounder **** and the threads are wider apart from the shift numbers. and the jdm version has a conical type aluminum/titanium ****.
**edit** remember this is a jdm **** not a usdm.
Modified by cxSHOE at 12:57 PM 8/7/2004
Modified by cxSHOE at 1:00 PM 8/7/2004
Old Aug 6, 2004 | 10:31 PM
null.'s Avatar
Default Re: is this oem or aftermarket shift ****? (cxSHOE)
could be the 1999/2000 si shift *****, if not it sure is similar to it
Old Aug 6, 2004 | 10:35 PM
cnyej1's Avatar
Default Re: is this oem or aftermarket shift ****? (egb18turbo)
I think that i have sen that on a EP3 SI.... see the fitting at the bottom... the 99-00's dont have that... but the EP's do I believe
Old Aug 6, 2004 | 10:41 PM
civic4dr's Avatar
Default Re: is this oem or aftermarket shift ****? (cnyej1)
2002 si
Old Aug 6, 2004 | 10:43 PM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egb18turbo &raquo;</TD></TR><TR><TD CLASS="quote">could be the 1999/2000 si shift *****, if not it sure is similar to it</TD></TR></TABLE>
doesnt the thread go all the way down?? instead of stopping at the top??
Old Aug 6, 2004 | 10:44 PM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cnyej1 &raquo;</TD></TR><TR><TD CLASS="quote">I think that i have sen that on a EP3 SI.... see the fitting at the bottom... the 99-00's dont have that... but the EP's do I believe </TD></TR></TABLE>
ok, yea ive never step in an ep3 si so im clueless on their *****..
Old Aug 6, 2004 | 10:47 PM
cxSHOE's Avatar
Default Re: is this oem or aftermarket shift ****? (civic4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic4dr &raquo;</TD></TR><TR><TD CLASS="quote">2002 si</TD></TR></TABLE>
ok so that 2nd's on the ep3 si . are the jdm ***** the same as the usdm. because this is for sure a jdm **** since its coming from my cousin in japan. thanks anymore info, photos etc...
Old Aug 6, 2004 | 10:49 PM
ek9800's Avatar
EP3 SI or ITR
Modified by jdm98hb at 12:22 PM 8/8/2004
Old Aug 6, 2004 | 10:53 PM
cxSHOE's Avatar
well its not from a usdm ep3 si here is a photo of one and you see how the thread pattern takes a wider pattern from the 2 and r shift points , and my **** takes a closer pattern much like the 97 itr and prelude optional ****.
more info guys. ill see what i can find on the japanese webpages.
Old Aug 6, 2004 | 11:00 PM
cxSHOE's Avatar
and i just realized that the jdm ep3's have aluminum or titanium conical ****. i wonder if there was an optional leather **** for the jdm ep3's???
Old Aug 6, 2004 | 11:52 PM
eg6sir-s's Avatar
the **** could be from a prelude...ill have to double check.
Old Aug 7, 2004 | 12:03 AM
Chong's Avatar
ballin
definatley not from USDM ep3... my dad has an '04 Si has the numbers dont look like that. The **** does look similar thou.. check it
Old Aug 7, 2004 | 12:57 AM
bs-inc's Avatar
Default Re: is this oem or aftermarket shift ****? (Chong)
97 ITR ****?
Old Aug 7, 2004 | 01:26 AM
dampachi's Avatar
Default Re: is this oem or aftermarket shift ****? (bs-inc)
i would say an optional prelude because preludes have those clips on the bottom of the *****.
Old Aug 7, 2004 | 08:31 AM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chong &raquo;</TD></TR><TR><TD CLASS="quote">definatley not from USDM ep3... my dad has an '04 Si has the numbers dont look like that. The **** does look similar thou.. check it
nice clearer photo. yea its definitely not a usdm ep3 si ****. thanks.
Old Aug 7, 2004 | 08:33 AM
cxSHOE's Avatar
Default Re: is this oem or aftermarket shift ****? (dampachi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dampachi &raquo;</TD></TR><TR><TD CLASS="quote">i would say an optional prelude because preludes have those clips on the bottom of the *****.</TD></TR></TABLE>
remember it is not a usdm ****. not sure if jdm preludes had a leather optional **** like we did, and ours has the red stitching all the way down on both sides. it didnt stop like it is on this one.
Old Aug 7, 2004 | 09:24 AM
Calvinator's Avatar
looks like ep3 si or 97-98 itr?
Old Aug 7, 2004 | 11:59 AM
cxSHOE's Avatar
Default Re: (xtremeazian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtremeazian &raquo;</TD></TR><TR><TD CLASS="quote">looks like ep3 si or 97-98 itr?</TD></TR></TABLE>
looks are decieving although... the ep3 has the threads going around the ****, and not down the backside. and the itr has both threads that go down the front and backside of the ****. and this one stops on the backside..
anyone else???
Old Aug 17, 2004 | 11:00 PM
eluder33's Avatar
thats a subaru wrx (2003-04) shift ****. I sat in one the other day and thats the same exact one. It not a prelude **** either cause I have one and it got two clips at the bottom for the chrome ring to hold the boot up.
4EN[sic]
Jun 27, 2015 03:09 PM
johnclaunch
May 24, 2006 11:31 AM
xdjoynerx
Mar 10, 2004 04:37 PM
kkim
Sep 12, 2002 09:58 PM
jet
Mar 19, 2002 10:48 AM
