Knowing ignition timing with aluminum flywheel, SOL?
Old Nov 29, 2001 | 11:06 AM
boomslang's Avatar
Default Knowing ignition timing with aluminum flywheel, SOL?
I installed a CM aluminum flywheel in a while back and my dumbass forgot to have the degrees etched in by a machine shop. There is a TDC mark and that is it.
I know the timing is 15 degrees right now, that is what it was before the install. Is there any way to change it and actually know what it is without the fw marks?
Old Nov 29, 2001 | 12:59 PM
Crazydave's Avatar
Default Re: Knowing ignition timing with aluminum flywheel, SOL? (Inlinefour)
correct me if I'm wrong... but aren't the timing marks on the crank pulley?
Old Nov 29, 2001 | 02:41 PM
sgT's Avatar
sgT
Default Re: Knowing ignition timing with aluminum flywheel, SOL? (Crazydave)
not on F and H motors
Old Nov 29, 2001 | 03:11 PM
sackdz's Avatar
Default Re: Knowing ignition timing with aluminum flywheel, SOL? (sgT)
I still don't understand why you'd need timing marks on the flywheel.......? You can't see it...
Old Nov 29, 2001 | 03:17 PM
Crazydave's Avatar
Default Re: Knowing ignition timing with aluminum flywheel, SOL? (sackdz)
well put some on the crank pulley... make your life easier!
Old Nov 29, 2001 | 04:56 PM
boomslang's Avatar
Old Nov 29, 2001 | 08:47 PM
Blown90hatcH's Avatar
Pull the #1 plug...get a really long 3/8 drive extension...long like 2 ft one.....put it down into the # cylinder...turn the crank until the extension is at the top of the stroke....Mark the crank pulley.
Jason
Old Nov 29, 2001 | 09:25 PM
boomslang's Avatar
Default Re: Knowing ignition timing with aluminum flywheel, SOL? (Blown90hatcH)
I already have a TDC mark though. But no degree marks.
Old Nov 30, 2001 | 06:42 AM
sgT's Avatar
sgT
use an advancing timing light.
Old Nov 30, 2001 | 06:48 AM
Greyout's Avatar
nice timing lights let you set your own advance on the gun... so you set it for what you want, and then time it to TDC.... (what he said )
Maddox
Feb 29, 2004 07:24 PM
preluda92
Oct 24, 2003 09:41 AM
dvp95
Aug 21, 2003 07:45 AM
BoostedH23a1
Jan 18, 2003 05:33 AM
civbeater90
Nov 16, 2002 12:46 PM
