Injector Problem >=O
Old Aug 6, 2004 | 07:50 PM
integraracing91's Avatar
Default Injector Problem >=O
After swapping in a OBD1 B18a into my 89 crx si, the engine would turn over and crank but wouldn't start up. Keep in mind I stayed OBD1 so i tried to use the integra's injectors and i eliminated the resistor box and such.
So I unbolted the fuel rail and tried to start it again. One of the fuel injectors came flying out so the rail is getting pressure, but made me think they weren't firing. So I rewired in the resistor box and put the crx injectors and clips in, but they still aren't firing which leaves me stumped =\ ...
This ever happen to anyone else?
Old Aug 7, 2004 | 11:42 AM
Default Re: Injector Problem >=O (integraracing91)
bump
Old Aug 7, 2004 | 11:52 AM
Redline130's Avatar
What ecu are you using? Distributor? Did you use a OBD0-OBD1 conversion harness?
Old Aug 7, 2004 | 11:54 AM
MENACE's Avatar
There's alot more things that you could tell us. Did you check for spark. Is the motor timed Correctly. Did you recheck everything that you wired up. Stuff like that.
Old Aug 7, 2004 | 02:29 PM
Default Re: Injector Problem >=O (Redline130)
I'm using the 92 integra ECU and dizzy, and i also used a conversion harness. I checked for spark and getting nothing, im trying some new spark plugs wires because i believe they may have been damaged while i was installing the engine. Timing is good though and i''ve been rechecking my wiring.
When i reinstalled the injector box i matched like color wires (red/black -> red/black and so on)
Any parts of the conversion wiring i should specifically check?
Thanks for the help keep it coming
Old Aug 7, 2004 | 02:41 PM
89s1's Avatar
the actual firing order of the spark plug wires themselves...
If you aren't getting spark though, I would change cap/rotor... if you still see no spark you probably have a bad dizzy.
Old Aug 7, 2004 | 02:50 PM
MENACE's Avatar
Default Re: Injector Problem >=O (89s1)
Do you Have a votlmeter? If so check youre Coil. I realy dont think its the plug wires. Ive never seen a car not start because of wires. Recheck the grounds. But it seems like it is the Dizzy. If you dont have spark.
Old Aug 7, 2004 | 02:52 PM
UltimX's Avatar
No ground? Your probably getting fuel but just no spark.
Old Aug 7, 2004 | 08:21 PM
Default Re: Injector Problem >=O (UltimX)
I have a voltmeter, but how do I check the coil? And I'm getting fuel but my injectors just aren't firing. I'm also going to check the voltages on the injector clips too just to see what the readings are. Anyone know what they are supposed to be?
Old Aug 9, 2004 | 09:44 PM
I just rechecked and im getting definate spark, and my fuel rail is definatly getting pressure. But the injectors are not firing or opening or w/e.
SO ANY ANSWERS OR SUGGESTIONS WOULD BE AWESOME
Thanks.
Old Aug 10, 2004 | 02:25 PM
Bizzump
Old Aug 15, 2004 | 03:58 PM
JohnMumie
Jan 8, 2013 10:54 AM
supra_king87
Jan 13, 2010 10:07 PM
sikefcrx89
Sep 1, 2009 05:20 PM
white90rexsi
Jun 22, 2007 06:21 PM
integraracing91
Aug 6, 2004 07:34 AM
