pioneer 4600mp help
Old Aug 6, 2004 | 05:56 PM
Sarren's Avatar
Default pioneer 4600mp help
I just bought this and started putting it in today. I finished not too long ago, and for some reason the right front speaker is not working at all. I checked the corresponding wires and, from what I know, (I called Crutchfield and they confirmed the wires just match by color) everything is completely correct. Is there some problem with these I'm not aware of or did I just get a faulty unit?
Old Aug 6, 2004 | 06:16 PM
Eric R's Avatar
Default Re: pioneer 4600mp help (Sarren)
There are so many things to check for.
Could be a blown speaker?
A loose or bad connection?
The least possible thing, a defective radio?
You can pull the radio out and disconnect that channel. On one side, check with a battery between (+) and (-) to see if the speaker is blown or if there is a good connection between that point and the speaker. On the other side, use another "test" speaker to check if there is sound coming out of that output.
Good luck!
Old Aug 6, 2004 | 08:55 PM
Sarren's Avatar
Default Re: pioneer 4600mp help (Eric's R)
I'm going to check the speaker tomorrow, that really is the only other thing that I can think of that could be wrong... I made sure everything was solder'd correctly, checked the wires, tested it with a meter, everything was good..
Old Aug 7, 2004 | 11:32 AM
Sarren's Avatar
Checked out the speaker, it was disconnected.. reconnected, completely dead.. fortunately I had just ordered a pair of speakers the day before so I'm good
one small other problem, the stupid crappy cheap frame they sent me to put it in snapped in half while putting it in, made a sort of makeshift one for now.
Old Aug 7, 2004 | 12:50 PM
Eric R's Avatar
@5200
Audio / Security / Video
Mar 18, 2009 08:15 PM
NuRon
Mar 7, 2008 12:11 PM
JDM_Frijoles
Dec 31, 2006 11:35 AM
kevinoneill
Feb 19, 2004 07:13 PM
92GSR
Jul 19, 2002 02:26 PM
