O2 Sensor Wiring Help!!!!
Hey all. I'm doin a header and cat install on my buddy's 94 GSR. When I unbolted the cat, it dropped and the 4 wires came out of the harness. So now I'm just tryin to figure out which wire to put back to each spot. Does anyone have a link to a wiring diagram that shows which wires go where?
There are 4 wires that go to the harness from the o2 sensor: 1)Black, 2)Black (maybe more of a dark brown), 3)Green, and 4)White.
With the part that clips being the top side, can anyone tell me where to put each pin into. Help is much appreciated. Thanks in Advance!
From: Formerly of SF moved to DFW and now back in SF, CA, USA
With the bigger clip section on top try this:
Top row looking at clip end: White, Green
Bottom row: Black, Black
Hope this helps.
Hope this helps.
