Warning to those with aftermarket rear sway bars and/or other suspension mods....
Old Aug 6, 2004 | 04:31 PM
LudeyKrus's Avatar
Default Warning to those with aftermarket rear sway bars and/or other suspension mods....
If you have your Prelude set up for handling, and have made the rear end much stiffer than stock, then please be careful when you are forced to put a donut on your rear wheel!
Two days ago I had a flat and was forced to put a donut on till I could get to a tire shop to have my tire fixed. In those two days I have swung the rear end around twice accidentally!!! I am running a ST rear sway bar w/ Koni yellow's and Neuspeed Sports.
The first time was simply taking a corner at just over the speed limit and lifting off the throttle while in the corner. The second was turning right onto an exit ramp doing what would normally be somewhat slow. Each time the rear end snapped out, I compensated, it pitched back the other way, and caught it.....nothing was damaged and everything was alright except for my nerves. I still have 2 more days to drive on this bastard of a tire, though.....
So be careful! It's something you may not think about till you're already in a ditch......or staring at an oncoming car's headlights.
Old Aug 6, 2004 | 11:51 PM
Not_Rice4ws's Avatar
good to know lol...
i have neuspeed front and rear sway bars on my 92 4ws si. ill bet its even worse with 4ws and a donut on back. is yours 4ws?
Old Aug 7, 2004 | 08:19 AM
4thgenlude's Avatar
Default Re: (Not_Rice4ws)
thats definetely good to know
ive got Konis yellows with Neuspeed sports too
did that sway bar make a big difference?
Old Aug 7, 2004 | 08:48 AM
SuperSlow's Avatar
Default Re: Warning to those with aftermarket rear sway bars and/or other suspension mods.... (LudeyKrus)
Good info.
Old Aug 7, 2004 | 09:32 AM
LudeyKrus's Avatar
Nope, I'm not a 4WS.
And yes, the sway bar made a huge difference, but I haven't had a chance to take my car out and fully push it since I've installed the sway bar.
Old Aug 7, 2004 | 09:45 AM
alphajesse's Avatar
Most FWD cars will get oversteer if you let off the throttle in a corner.
Even with normal tires and stock suspension.
I'm sure your car would have done the same if it was stock with the donut.
Old Aug 7, 2004 | 04:28 PM
TimeRacer's Avatar
Default Re: (alphajesse)
This is actually how the "JDM" cars get the rear to kick out. By running "less grip" tire sizing in the rear. With the donut you've even more extreme. Just drive slow slow, barely speed limit, don't take any turn faster than you would on a tricycle, you're on the spare, it's not designed to handle.
Old Aug 7, 2004 | 04:38 PM
LudeyKrus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alphajesse &raquo;</TD></TR><TR><TD CLASS="quote">
I'm sure your car would have done the same if it was stock with the donut.</TD></TR></TABLE>
I've had a donut back there before, and it was nothing like that.
It's def. worse w/ the sway bar back there.
Chillboy
Acura TL, RL & ZDX
Mar 18, 2011 05:14 PM
specialized108
56
Jan 25, 2009 02:27 PM
AamirCWITR
May 12, 2007 04:06 PM
integ3
Suspension & Brakes
32
Dec 26, 2006 09:44 PM
eg6madness
May 13, 2002 10:35 PM
