F22 vtec head on F22 non-vtec bottom-end???
Old Aug 6, 2004 | 03:15 PM
sicivic's Avatar
Default F22 vtec head on F22 non-vtec bottom-end???
Did a quick search and couldn't find anything. Can you bolt a F22B1 vtec head onto a F22B2 non-vtec bottom-end? Throw the vtec computer in the car and basically have a F22 vtec? Similar to the D16A6 bottom-end with a D16 vtec head in the civics?
Also, do the F22B1 and F22B2 transmissions have different gearing?
Old Aug 6, 2004 | 04:59 PM
Atheist's Avatar
Errr, think about this for a second. You have a vtec head, and you have an ecu for a vtec motor, what is actuating the solenoid?
I believe it is very similiar to a minime in the dseries.
Old Aug 6, 2004 | 05:12 PM
sicivic's Avatar
Default Re: (Atheist)
Well, you would have to run a wire from the pin on the ecu to the vtec solenoid. But I just curious if the head will bolt-in and the ecu will plug up.
Old Aug 6, 2004 | 05:42 PM
sicivic's Avatar
Default Re: (JdmLsPwr425)
OK?!?!?!?! Go away!
Old Aug 6, 2004 | 05:50 PM
The_Todd's Avatar
Farts in the shower
Default Re: F22 vtec head on F22 non-vtec bottom-end??? (sicivic)
Gearing should be the same...
But here is a write up for putting a f series vtec head on a non vtec f series block. (although its a f22a versus b2 its the same principle)
http://www.cb7tuner.com/vbb/sh...+swap
Old Aug 6, 2004 | 06:19 PM
JDM.Accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmLsPwr425 &raquo;</TD></TR><TR><TD CLASS="quote">damn im hornee for a 10" peanace in my ***
Damn public computer users
Old Aug 6, 2004 | 06:52 PM
FatJoe's Avatar
hmmm.... i like your signature too...
Old Aug 7, 2004 | 01:51 AM
CB7~Shawn's Avatar
been done, not worth the money in my opinion
Old Aug 7, 2004 | 04:26 AM
sicivic's Avatar
Default Re: (CB7~Shawn)
15hp and 8ft-lbs of torque for a couple hundred bucks isn't worth it? thats cheaper than a cat-back exhaust.
Also, are the F22B1 and F22B2 intake manifolds different?
Old Aug 7, 2004 | 05:55 AM
Mike813's Avatar
Default Re: (sicivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicivic &raquo;</TD></TR><TR><TD CLASS="quote">15hp and 8ft-lbs of torque for a couple hundred bucks isn't worth it? thats cheaper than a cat-back exhaust.
Also, are the F22B1 and F22B2 intake manifolds different?</TD></TR></TABLE>
read the write up that was provided to you... a step by step install is FULLY covered and should asnwer all your little questions.
bobbyisda1
Aug 4, 2009 02:32 PM
civictildeath
Aug 2, 2006 08:22 PM
Suck my DX
Jan 6, 2005 10:34 AM
acc97lxAndy
Aug 19, 2003 12:30 PM
stretchguy
Dec 29, 2002 11:44 PM
