Finally found my dyno sheet
did a couple runs at P1 a couple of months ago! and came up with 160.9hp @7700 and 116 tq @ 6400. this was on a mustang dyno for those who are not familiar with P1.
setup:
b18c5
p28 computer
comptech ice box
skunk2 stage 1 cams
skunk2 cam gears
jun valve springs
jun tit. retainers
racing spec 4-1 header
stock exhaust
test pipe
vfac
i think that is all as far as performance is concerned.
setup:
b18c5
p28 computer
comptech ice box
skunk2 stage 1 cams
skunk2 cam gears
jun valve springs
jun tit. retainers
stock exhaust
test pipe
vfac
shouldn't you be making more power than what you made at the dyno. Just with Intake, JDM 4-1 header, Test Pipe, Apexi N1 exhuast, and AEM EMS (Kinda Tuned) I made 176whp @ 8800RPM and 124lbs of TQ 8400RPM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm pwr »</TD></TR><TR><TD CLASS="quote">i beleive this is around 190-195hp on a dynojet dynometer. </TD></TR></TABLE>
Yeah, and I believe I'll live forever ....
NOPE..its about 175whp-180whp on a dynoject
i thought a mustang dyno was about 20% lower than a dynojet, i may be wrong.
i have never tested on dynojet so i dont know. it was just an estimate anyways.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obd2gsr »</TD></TR><TR><TD CLASS="quote">who gives a crap about peak #'s...
everyone cares about peak #'s. or course you want a clean and nice curve but peak #'s is mainly what everyone wants. higher the peak=the happier you are
</TD></TR></TABLE>everyone cares about peak #'s. or course you want a clean and nice curve but peak #'s is mainly what everyone wants. higher the peak=the happier you are
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinbro2 »</TD></TR><TR><TD CLASS="quote">
bench racers care.
it's nice, but i'd rather make less HP than someone yet run a faster 1/4 mile time...
i dunno, real performance or on-paper performance? you be the judge which one carries more credibility
</TD></TR></TABLE>bench racers care.
damn dude, i feel sorry. but here's a shamless plug of my best *basically stock* ITR setup.... dyno pic will be up in like 30 mins.
b18c5, stock block, stock head, stock everything internal, CTR intake cam, 98 ITR exhaust cam... 1 layer headgasket and 10 thou milled (approx. 11.2 or 11.3:1 compression), OEM ITR exhaust (removed bottlenecks), comptech icebox with OEM paper filter element.
then the typical mods... p28 skunk2, cam gears, v-afc, b&m fpr, 2.25" test pipe
190hp/130tq with toda header
188hp/130tq with dc sports jdm 4-1
178hp/126tq with usdm ITR exhaust manifold
yea, i know the toda was only 2hp more peak hp.. but it made like 5hp more than the dc from 4000-7600rpm. awesome header.
EDIT!
I apologize. I should give some constructive criticism. you should do the following....
1- valve adjustment
2- compression test
3- check/replace distributor cap and rotor
4- make sure you don't have a tank of 87 octane
if all else fails, i'll trade you my b16a EF hatch for it.
EDIT!
1- valve adjustment
2- compression test
5speed4life
111
Dec 9, 2010 08:13 PM
