B20/VTEC 92 DA WHICH HEADER TO USE?
Old Aug 6, 2004 | 02:54 PM
swiftstyles's Avatar
Default B20/VTEC 92 DA WHICH HEADER TO USE?
sup, I want to buy some dc headers for my ride. I was under the impression that all dc headers will give me the same results as long as its a b series header. My friend told me that I should get the Type R dc header. What is the different.
Old Aug 6, 2004 | 03:03 PM
rastropovitch
Guest
Posts: n/a
Default Re: B20/VTEC 92 DA WHICH HEADER TO USE? (swiftstyles)
Get a toda
Old Aug 6, 2004 | 03:20 PM
purplegsr's Avatar
Default Re: B20/VTEC 92 DA WHICH HEADER TO USE? (MSchu)
Any b-series header will fit on the b20 block, but depending on what your performance goals are you may want to select a different header.
If you definitely want a DC header:
DC 4-2-1 will give you some midrange power, but not all that much (2.25 in collector)
DC 4-1 for USDM 94-01 Integras will give you some decent midrange and high RPM power (2.25 in collector)
Your friend wants you to get the DC JDM (Type R) 4-1 for Integra Type R, this one is a 4-1 design, but also has a 2.5 in collector, which will require either a 2.5" test pipe or a high flo cat. I figure you are running a b20, so you will have to do some welding/cutting of your muffler and cat/testpipe anyway, so you might as well get the 4-1 JDM TypeR.
All 3 should cost around $250 or less.
There are lots of headers out there that make more power and have better build quality than DC: Toda, AN-R, Bisimoto, Hytech, SMSP, Comptech, etc but they tend to be far more expensive.
Old Aug 6, 2004 | 04:35 PM
Padawan's Avatar
Darth ModerVader
Default Re: B20/VTEC 92 DA WHICH HEADER TO USE? (purplegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr &raquo;</TD></TR><TR><TD CLASS="quote">DC 4-2-1 will give you some midrange power, but not all that much (2.25 in collector)
DC 4-1 for USDM 94-01 Integras will give you some decent midrange and high RPM power (2.25 in collector)</TD></TR></TABLE>
Just to clarify, none of the DC Sports headers have a 2.25" collector. All headers that are designed to bolt-on directly to "USDM" Integras (including DC Sports) have 2.00" OD collectors. The only headers that I know of with 2.25" collectors are custom-made pieces.
Old Aug 6, 2004 | 08:35 PM
purplegsr's Avatar
Default Re: B20/VTEC 92 DA WHICH HEADER TO USE? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
Just to clarify, none of the DC Sports headers have a 2.25" collector. All headers that are designed to bolt-on directly to "USDM" Integras (including DC Sports) have 2.00" OD collectors. The only headers that I know of with 2.25" collectors are custom-made pieces. </TD></TR></TABLE>
Yeah, you are correct, sorry for the misinfo. My overall point was you should get the 2.5" collector with the JDM Type R header.
Old Aug 7, 2004 | 05:43 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr &raquo;</TD></TR><TR><TD CLASS="quote">My overall point was you should get the 2.5" collector with the JDM Type R header.</TD></TR></TABLE>
I completely agree, especially on a 2 litre VTEC setup. Any other DC header would just be choking the motor.
Old Aug 7, 2004 | 05:59 AM
arw321's Avatar
Don't forget you are going to have to notch your front crossmemeber to run the jdm 4-1 on a DA. I've been through it, it's not much fun.
Old Aug 7, 2004 | 07:51 PM
matman4444's Avatar
Default Re: B20/VTEC 92 DA WHICH HEADER TO USE? (arw321)
anywhere that i can read about notching the crossmember? i have this same setup same car and everything.. need a header too! will most muffler shops install a header and make some custom pipe or whatever is needed to hook up to the exhaust?
Old Aug 9, 2004 | 09:33 AM
purplegsr's Avatar
Default Re: B20/VTEC 92 DA WHICH HEADER TO USE? (matman4444)
you could check out the full race, z1, or place racing crossmember and see if any of them would fit with the 4-1 header, check out http://www.g2ic.com, I bet there is more info on this over there.
8krdline
44
Feb 13, 2005 09:01 AM
CR-V
Mar 20, 2003 07:32 PM
jdm4life
Dec 15, 2002 06:42 AM
808State
Sep 23, 2001 12:54 PM
