Does ANYONE have a spare ecu plug???
Old Aug 6, 2004 | 11:54 AM
RabbittZ's Avatar
Default Does ANYONE have a spare ecu plug???
looking for just spare ecu plug to extract like 4 ecu pins out of with a bit of wire attracted. if someone could be so generous as to help someone out, id be most thankful.... thanks
Old Aug 6, 2004 | 11:59 AM
PHiZ's Avatar
Default Re: Does ANYONE have a spare ecu plug??? (RabbittZ)
Big pins or small pins. Make me an offer.
-PHiZ
Old Aug 6, 2004 | 12:03 PM
Cnote's Avatar
send 1.42 to
carlos_tss@hotmail.com
and you'll have your pins
Old Aug 6, 2004 | 12:41 PM
RabbittZ's Avatar
just need spins for ecu.. swapping 95 gsr into 95 cx... you all should know the situation im in ... so thats what i need..
either of you guys have what ill be needing???
Old Aug 6, 2004 | 01:25 PM
PHiZ's Avatar
Default Re: (RabbittZ)
There are two sizes of pins, large and small. If you post up what pins you are doing, that may help.
I'm guessing Vtec, Vtec Oil Pressure, KS, and IABs.
http://tech2.hybridgarage.com/..._obd1
-PHiZ
Old Aug 6, 2004 | 01:32 PM
RabbittZ's Avatar
phiz.. you nailed it on the dot... what sized pins will those be??? can you help a brother out?
Old Aug 6, 2004 | 03:04 PM
PHiZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RabbittZ &raquo;</TD></TR><TR><TD CLASS="quote">phiz.. you nailed it on the dot... what sized pins will those be??? can you help a brother out?</TD></TR></TABLE>
Use the link I provided and post up the pin numbers.
-PHiZ
Old Aug 7, 2004 | 08:58 PM
Cnote's Avatar
A4-vtec solenoid
A17-IAB
D3-Knock
D6-vtec pressure
gorthjr
May 11, 2010 08:55 PM
nicko360
Mar 28, 2007 03:59 PM
EG civic
Jun 16, 2006 08:22 PM
