Gsr Header On LS
Old Aug 6, 2004 | 10:20 AM
Droppedatbirth!'s Avatar
Default Gsr Header On LS
i have a 94 ls and a gsr dc header will it work with no probs? bolt up?
Old Aug 6, 2004 | 10:42 AM
jweezy225's Avatar
Default Re: Gsr Header On LS (redzcrex)
i dont think so...
Old Aug 6, 2004 | 10:56 AM
shermanyang's Avatar
Default Re: Gsr Header On LS (jweezy225)
it will bolt right up to your motor...but it won't bolt up to your cat.
Old Aug 6, 2004 | 11:05 AM
jweezy225's Avatar
Default Re: Gsr Header On LS (shermanyang)
how big is the piping on the gsr header as opposed to a LS header? well... the area that connects to the CAT
Old Aug 6, 2004 | 11:08 AM
purplegsr's Avatar
piping size is the same in terms of diameter, but the pipe is a different length. To put it into perspective, you can either run a GSR header, GSR cat, and GSR exhaust on the LS and it should fit perfectly (they need to be from the same time period - meaning 94-99 or 00-01) - or you can use a GSR header and see where the mismatch occurs using LS cat and LS exhaust piping, then modify from there.
Old Aug 6, 2004 | 01:24 PM
Default Re: Gsr Header On LS (purplegsr)
what if i buy a gsr exaust would it all bold up then?
Old Aug 6, 2004 | 01:44 PM
purplegsr's Avatar
you need a gsr cat too, it will be more cost effective to just weld the exhaust piping to fit the GSR header. Also, the measurements from 94-99 and 00-01 GSRs are different, so you would need all 3 parts from the same set of years.
Old Aug 20, 2004 | 09:20 PM
nygsr's Avatar
Default Re: Gsr Header On LS (Slammed)
how much will u want for ur gsr header. is it dc and u think it will fit my four door gsr
xlilninjax
Oct 28, 2010 01:09 PM
hamburgler
Jan 13, 2006 08:41 AM
DsBananas94LS
Aug 8, 2004 05:48 PM
eg64u
Aug 1, 2004 02:44 PM
imonkie
Jan 14, 2003 06:48 PM
