turbo issue
Old Aug 6, 2004 | 08:49 AM
A2RAYA's Avatar
Default turbo issue
how much can i load with my turbo witout changing any fuel injections? D16z5 is the motor code..
Old Aug 6, 2004 | 09:05 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: turbo issue (A2RAYA)
Depends on a lot of factors. What is the condition of your motor? Did you do a compression check?
Old Aug 6, 2004 | 09:06 AM
A2RAYA's Avatar
Default Re: turbo issue (shamoo)
yes and all that was fine..but there is a guy who says that it won´t work?? but the dealer who I bought it from says that it will?? who should I trust?
Old Aug 6, 2004 | 09:18 AM
crx_88_si's Avatar
honda injectors are at like 85% duty cycle in NA form. you WILL NEED larger injectors if you decide to use a AFC or standalone management. If you do however decide to use a FMU (i dont suggest it) you can use the stock injectors.
tsdneil
May 7, 2008 01:54 PM
VTteg
May 7, 2006 06:19 AM
VTteg
Feb 28, 2006 04:20 PM
TuningOptions
Sep 1, 2004 12:43 PM
losder riper
Jul 9, 2004 09:49 AM
