Problem to shift since I installed a new Action clutch 2MS ? Take a look please.
Old Aug 6, 2004 | 06:56 AM
yellowturbo's Avatar
Default Problem to shift since I installed a new Action clutch 2MS ? Take a look please.
Ok I dont want to said that the Action clutch is the main problem BUT its related cuz before I didnt have anyproblem to shift... 2MS
The main difference between my old and my new clutch is the pressure plate pressure... the old one was double but the new one is a lot stronger... especially on the pedal effort loll
Well the biggest problem is to shift from the first gear to the second... at low rpm ( 1000 to 5000 ) all is fine ... but when I floor it and want to shift at 8000 Im able to disangage the first gear but when the shifter is in the *neutral* position I feel like the second gear doest want to engage.... and when the rpm drop I can put it in second gear ( all this takes like 1 second but seems to be an eternity loll )
I use Honda MTF tranny oil and all is fine there....
Thanks !
Old Aug 6, 2004 | 08:06 AM
m R g S r's Avatar
Default Re: Problem to shift since I installed a new Action clutch 2MS ? Take a look please. (yellowturbo)
Did you install the clutch disk backwards? Did you replace the throwout bearing and pilot bearing? Those are the only things I can think of that you could mess up when doing a clutch install. . .
Old Aug 6, 2004 | 10:27 AM
A shop did the installation... but ELSpool told me that it could be my engine mount who are too soft...I only got the 3 principal ...the rear one, tranny, cam gear.... OEM...
He saw my car on the dyno and told me that my engine was going to pop out ...
So its maybe this... I have some insert that I will put on tonight.
Old Aug 9, 2004 | 11:15 AM
well it was not the engine mounts... even with the inserts the problem still there...
ANYONE have an idea... someone talked about installing the disk backward ?? How it is possible ??
Old Aug 9, 2004 | 11:22 AM
Tinker219's Avatar
Default Re: (yellowturbo)
check to see that the clutch line is fully bled?
Old Aug 9, 2004 | 11:30 AM
I will take I look but the clutch pedal seems to be good, shes really hard....
I begin to think that the shop didnt reinstall the shifter linkage and my shifter stick properly ....
Old Aug 9, 2004 | 12:29 PM
ATS*Mark's Avatar
OG triple OG
ill bet you 100 bucks all it is , is that the shop tightented the bolts on the shift linkage too tight.
Old Aug 9, 2004 | 12:31 PM
Honda Hick's Avatar
I had this problem on my car, but I have a cable clutch. I adjusted it a bit and it went away. I don't think there is any kind of adjustment on your hydraulic clutch.
Old Aug 9, 2004 | 12:50 PM
thanks guy !!! let your idea comming I will look at this tonight ...
Old Aug 10, 2004 | 12:28 PM
KTeller8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowturbo &raquo;</TD></TR><TR><TD CLASS="quote">thanks guy !!! let your idea comming I will look at this tonight ... </TD></TR></TABLE>
clutch cable too lose?
shift linkage too tight?
both?
Old Aug 12, 2004 | 07:54 AM
nope all is ok... I think that the problem is in the tranny but at low rpm all is really fine ??? could it really be the clutch itself ???
shadowfox375
Honda Civic (2006 - 2015)
30
Apr 15, 2009 05:57 PM
MatticusContra
Jan 10, 2008 11:27 AM
JFG Kevin
May 7, 2006 12:12 PM
Ryanm
Dec 18, 2004 05:19 PM
