GSR(B18C1) stock intake fit on GS (B18B1)?
Old Aug 6, 2004 | 04:31 AM
SchoolN'U's Avatar
Default GSR(B18C1) stock intake fit on GS (B18B1)?
Hey guys, I need to put on a stock intake system and I found one off a 99 GSR. Will this work/fit on my 1998 Integra GS?
Old Aug 6, 2004 | 06:06 AM
3.504's Avatar
Default Re: GSR(B18C1) stock intake fit on GS (B18B1)? (SchoolN'U)
the gsr's TB sits alot lower than a GS's does. try finding the ls/gs/rs intake, or use an ITR intake, or even try one of the EG chassis intakes. those should all work out for you. in all honesty, the stock intake is just that ribbed plastic that can flex, so you can more than likely make it fit... easiest thing would be ls/gs/rs.
Old Aug 6, 2004 | 06:35 AM
SchoolN'U's Avatar
Default Re: GSR(B18C1) stock intake fit on GS (3.504)
thanks, I have the stock flexable neck part fromt he GS engine, the many parts that is the actually factory airbox.
Old Aug 6, 2004 | 06:39 AM
3.504's Avatar
Default Re: GSR(B18C1) stock intake fit on GS (SchoolN'U)
i dont know if all the ducting is the same, but you can get the pipe and airbox on
99_red_si
Oct 30, 2007 06:45 AM
RA217252
May 25, 2005 05:59 PM
97teg415
Sep 17, 2004 06:51 PM
notstock93
Dec 8, 2003 05:59 PM
