i got a problem an i question
Old Aug 5, 2004 | 10:38 PM
si90civichb's Avatar
Default i got a problem an i question
i got a problem with my d16a6, the problem is that i blowing out white smoke when i rev to 7200 and then after the it stop about 1 min later. an i change the oil an the plug too an it still does it an the headgasket it still good to an the front seal are good too, so what could be the problem, and another thing what in inturnals an i used from my motor. like b16a or a2 b18c5 or b18a1 an can i use other parts.
Old Aug 5, 2004 | 10:43 PM
5litereater's Avatar
Default Re: i got a problem an i question (si90civichb)
use punctuation marks.
anyways. you cant use any bseries parts on your dseries cuz the b's are DOHC (dual overhead cams) and the d's are SOHC (single overhead cams). however, that doesnt mean you can't attain the power of a bseries. pick up an intake, header, exhaust and maybe some cams with cam gears and your d should move. maybe mid 15's if you can drive it?
anyways good luck on your build...
Old Aug 5, 2004 | 10:54 PM
well see man i do run 15 with exhuast, header, an it chip too, an power banned, an intake but the thing i blowing white smoke out with i rev high rpm's
Old Aug 5, 2004 | 10:59 PM
spaceman's Avatar
white smoke? umm im tired does that say your burnin coolant or oil..lol sorry dood,speed bump
Old Aug 6, 2004 | 02:22 AM
piles's Avatar
Default Re: i got a problem an i question (spaceman)
coolent probably a head gasket is going. At higer rpms pistons move faster along with everything in the motor so it could be getting ready to go. I would not beat on it and change it as soon as you can
Old Aug 6, 2004 | 04:34 AM
CRX T-Si's Avatar
Default Re: i got a problem an i question (piles)
At 7200RPM I believe he is burning oil.
That motor gots to have lots of miles on it.
It's your piston rings man, have you checked your oil level lately?? does it like disappears like crazy.....
killudie123
Nov 6, 2011 08:14 AM
viper_2_4
Aug 15, 2006 09:51 PM
B00STED Si
Feb 3, 2005 10:52 AM
95dc2
Dec 9, 2003 11:55 AM
